Is Motion Possible in a Continuous Space?
  • Context: Graduate
  • Thread starter Thread starter JK423
    Discretization Space
41 replies · 7K views
Nugatory said:
Your conclusion might be valid if the points you're talking about were something physical, like little tollbooths that the object is required to check in at as it moves. But they aren't. They're a mathematical construct that allows us to attach numbers (which we call coordinates) to the positions of a moving object. That is, the moving object came first, and the notion that there are "points" at which it is located is our invention layered on top of that.
We choose the math to describe how the world works; we don't choose the math and then demand that the world conform to it.
Ok i agree with the description that you have given, except from the sentence "Your conclusion might be valid if the points you're talking about were something physical". But what you've just said in no way implies that my argument is wrong. Why do you require from the points to be physical for my argument to be correct? What i have done, is a one-to-one correspondence between the real numbers and the points in space. If you accept that, then you have to accept the rest. No need put matter in, I'm not sure what you have in mind. Please elaborate more if you insist on your view, and in that case please formulate your opinion by defining everything that you're saying. (e.g. the sentence "...were something physical, like little tollbooths..." doesn't make sense to me)
Astronomy news on Phys.org
JK423 said:
I'm not saying there is no time, I'm saying that time is irrelevant. Assume that time is flowing in what I've been saying. When you say "you can match each different point in space to a different point in time" you assume that can go from one point a different point. In the post 11 i argue that you cannot go from one point to a different one, regardless of whether time is flowing or not. So what you are saying is blocked by my argument.
The question is: Is my argument flawed? If yes, why?
Note that the same argument can be applied to time as well, to show that if you assume time to be continuous then it wouldn't be able to flow. But we have no idea what time is so let's leave that. Motion in space is more intuitive.
As a general remark, it's quite interesting that continuous spaces in general seem to be unable to deal with "flow".
Yes, of course you can go from one point to another. At one time you are here, at the next time you are there. You don't have to move from closest point to closest point. Just move large distances in discrete time. No problem - the question is can you do so in continuous time with finite speed.
Ok, so you choose to discretize motion instead of space. That's an option as well! :wink:
Yes, it's not so different from discretizing space in this sense: assume you have the real numbers, but that you can only jump from integer to integer. The integers are discrete but are embedded in the reals, so since the reals contain discrete things, you can move.
Anyway, since hopefully now you agree we can move in continuous space, why don't you take a look a look at the calculus, which answers whether you can move smoothly in continuous space.
JK423 said:
Please don't read just one sentence and just comment on that. Read the whole post and tell me your specific problem with the argument that I've given if you want to contribute.
yea I read the whole thing. Are there an infinite number colors in a rainbow? Perhaps it becomes a matter of defining a color (coordinates), as opposed to attempting to segregate the overlapping of frequencies. Much like how space & time "overlap" continuously. So depending on our "angle of view" a meter of length for you maybe a "meter" of time for me.
You are trying to conclude something about reality, based on a false premise (spacetime concept seems fairly agreed on).
The specific problem is not considering time to be a component of motion, let alone space.
If they aren't something physically real, if they're just mathematical abstractions, all you have a is a formal mathematical structure and a correspondence with another abstraction, namely the real numbers. Sure, in that structure there's always a point between any other two points... But why does it necessarily follow that that property of your mathematical model describes the motion of physical objects?
Ibix has already given you a pretty good hint when he pointed out that your mathematical model doesn't include the passage of time, which seems like <understatement>something of a defect</understatement> in a model of motion. Include time in the model, do some calculus, and you'll end up with phyti's answer.
The fact that you impose discrete motion has consequences: you don't have to move from the closest point to the other. This is what you've said before. If you accept this, then you cannot also accept what i have in bold, that smooth motion is possible. If you accept smooth motion, then you have to go from closest point to the next, and if you accept the latter then my argument at post 11 says that motion is impossible.
Hence, you're believing in two incompatible things that cannot be true simultaneously.
My answer to the bolded: If you agree that space and real numbers are in one-to-one correspondence (definition of continuity), then the property that there is always a point between two other points holds for space as well. If you accept that motion is smooth without jumps, then in order to go from one point to the other you need to pass from all points in-between (if you don't pass through all intermediate points, then you don't move smoothly, there are jumps). That implies that motion is impossible from my argument in post 11.
Hence, if you accept ALL the following,
1) 1-to-1 correspondence between space and real numbers (i.e. space is continuous)
2) motion is smooth (i.e. in order to go from point x0 to point x1 you need to pass from all points in-between, otherwise there are jumps )
then motion is impossible.
About the concept of time: Of course there is time, time is implied. When i say, "go from point x0 to point x1" you need time to do that. The fact that when you are at point x0, there is no next point different than x0 in a continuous space (hence motion is impossible) has nothing to do with time. Time is still flowing, it's just that it's impossible to move in such a space.
JK423 said:
I assume your argument is the same with atyy's post 23. If yes then I've given my reply in my previous post 27.
Your argument is that, no matter how closely you look, there are always an infinite number of points between any two points in continuous space. I'm just pointing out that, however close you look, there are always an infinite number of slices of time to visit them in.
If you are uncomfortable with that kind of ininite regress I suggest you learn some calculus. The whole concept of integration (a sum of an infinite number of infinitely small areas), for example, would be impossible if your argument were valid.
I re-write part of my previous post about time:
Let's say space and time are continuous. Discrete motion means the displacement time graph looks like a series of steps: you are at one spot at some time, then suddenly you are at another spot Δx away at a time that is Δt later. Your average speed is Δx/Δt. Now if you take Δx and Δt to be smaller and smaller, does your speed go to zero? If your speed goes to zero, them obviously you cannot move continuously. However, you can see that although the numerator Δx is getting smaller, the denominator Δt is also getting smaller, so the speed is not necessarily going to zero. What the calculus does is to make the argument rigourous that you can take Δx and Δt to zero, but Δx/Δt doesn't go to zero. So you have finite speed in infinitesimally small steps and you can move continuously.
Thread closed. We do not discuss nonsense philosophy at this site, and Zeno's paradoxes rank right up there on the nonsense scale.
