Is my logic correct? - L. Algebra question
  • Thread starter Thread starter JinM
    Algebra Logic
The discussion centers on determining the values of b and c in the augmented matrix to ensure the system is consistent and has a unique solution. The consensus is that the system is inconsistent when b equals 3 and c is not equal to 0. Additionally, the presence of free variables indicates that the system cannot have a unique solution, leading to the conclusion that infinite solutions exist when free variables are present. The participants clarify the conditions under which the system remains consistent and the implications of free variables on the solution set.
  • Understanding of linear algebra concepts, specifically augmented matrices.
  • Familiarity with row operations in matrix manipulation.
  • Knowledge of conditions for consistency and uniqueness in linear systems.
  • Ability to interpret and solve equations involving parameters.
  • Study the implications of free variables in linear systems.
  • Learn about the rank of a matrix and its relation to the number of solutions.
  • Explore the concept of row echelon form and reduced row echelon form.
  • Investigate the conditions for a system of equations to have a unique solution.
Students of linear algebra, educators teaching matrix theory, and anyone seeking to understand the conditions for consistency and uniqueness in linear systems.
JinM
Is my logic correct? -- L. Algebra question
\left[ \begin{array}{cccc} 1 & 2 & -3 & 2 \\ -1 & -2 & b & 3 \\ 0 & 0 & c & 2 \end{array} \right]
(1) For what values b and c is the system in the augmented matrix above consistent?
(2) For what values b and c does the system in the augmented matrix above have a unique solution?
I tried to simplify, and after a few row operations, I end up with:
\left[ \begin{array}{cccc} 1 & 2 & -3 & 2 \\ 0 & 0 & c(b - 3) & 5c \\ 0 & 0 & 0 & 2b - 6 - 5c \end{array} \right]Now I'm thinking this is it: the system is inconsistent for b = 3 and c != 0, and consistent for all other real numbers b and c.
Also, the system can never have a unique solution since there are free variables.
Is my reasoning faulty?
How did you eliminate your third row?
I have ...
\left[ \begin{array}{cccc} 1 & 2 & -3 & 2 \\ 0 & 0 & b-3 & 5 \\ 0 & 0 & 0 & \frac{2b-5c-6}{b-3} \end{array} \right]
I made a big mistake in calculating row equivalence! Never mind, I got what you have in your post now.
A few questions: how can you have unique solutions if you have a free variable? I'm inclined to think that we'll have infinite solutions if there is a free variable.
Also, how do you determine what c should be from the rightmost entry in the third row? I'm thinking we start from the second row, and say that b should not equal to 3 in order for the system to be consistent. I'm not sure how to deal with the constant 'c' afterwards.
Sorry! I'm currently taking this class and we just started going over this stuff. I don't have my book with me so I couldn't tell you. Wait for Dick or Halls of Ivy to respond or someone at their level to answer your question.
Oh I see. Thanks for your post.
How about this?
<br /> \left[ \begin{array}{cccc} 1 &amp; 2 &amp; -3 &amp; 2 \\ 0 &amp; 0 &amp; b - 3 &amp; 5 \\ 0 &amp; 0 &amp; 0 &amp; 2 - \frac{5c}{b-3} \end{array} \right]<br />
For the system to be consistent, we can all be certain that b should NOT equal to 3. Following on the same logic,
\frac{5c}{b-3}
should equal to 2!
Let's simpify,
5c = 2b - 6
b = \frac{5c + 6}{2}
But we already know that b != 3, so
\frac{5c + 6}{2} \neq 3
\Rightarrow c \neq 0
I think I might be going in circles here.
What do you mean by "free variables" ? Are you referring to b,c? In general, you would have infinite number of solutions if one or more rows of your final row-reduced augmented nxn matrix is nothing but zeros and the system is consistent. Another way to see it is that there are more unknowns than equations then you would have infinite solutions.
I don't understand your second question.
I assume you're addressing question 1. You have shown that it is necessary that 2 = \frac{5c}{b-3} holds. Since you only have one equation, you can't solve for specific values of b and c. That itself should be enough.
