Is my material Nanocrystalline or Amorphous? (XRD and Raman)
The discussion revolves around determining whether a thin film is nanocrystalline or amorphous based on Raman and X-Ray Diffraction (XRD) studies. Participants explore the implications of film thickness, diffraction patterns, and the limitations of various characterization techniques.
  • Experimental/applied
  • One participant notes that crystalline materials typically exhibit stronger, sharper peaks in Raman spectra, while nanocrystalline materials might show broad peaks that could resemble amorphous characteristics.
  • Another participant suggests that XRD should yield a pattern resembling powder diffraction rather than a clear single crystal pattern, raising questions about the potential differences in patterns for nanocrystalline materials.
  • Concerns are raised about the ability to distinguish between nanocrystalline and amorphous structures using Raman spectroscopy alone.
  • Some participants propose that scanning electron microscopy (SEM) could provide additional insights, particularly through techniques like electron back-scatter diffraction (EBSD) which can reveal grain orientation and structure.
  • There is discussion about the limitations of EDX/EDS in SEM, which primarily identifies elemental composition rather than crystal structure.
  • A participant explains that grazing-incidence X-ray diffraction could be a more effective method for analyzing thin films, as it minimizes substrate interference.
  • The Scherrer equation is mentioned as a potential tool for estimating grain size, with acknowledgment of signal-to-noise issues in the measurements.
Participants express differing views on the effectiveness of Raman and XRD techniques for distinguishing between nanocrystalline and amorphous materials. There is no consensus on the best approach, and multiple competing views remain regarding the characterization methods and their limitations.
Limitations include the dependence on the scattering geometry in XRD, the penetration depth of X-rays, and the resolution capabilities of SEM techniques. The discussion highlights the complexity of accurately characterizing thin films and the need for specialized equipment.
Black Nova
Hi!
How can I tell, based on my Raman and X-Ray Diffraction studies, if a thin film is nanocrystalline or amorphous?
The maximum thickness of my films is about 200nm, the XRay diffractograms showed nothing but the substrate (is it because of the thickness?), and my Raman spectra showed some broad (~70 cm-1), low intensity peaks (not as intense as the ones of crystalline samples).
I'm so confused, please help me!
Have a nice day
:smile:
Tough to say, crystalline media typically have stronger, sharper peaks, but lots of nanocrystallites might give you a broad distribution merged into a single peak which may resemble an amorphous-like Raman peak.
Claude.
I don't think you'll be able to tell the difference using Raman. As for XRD, instead of clear diffraction pattern that one sees for single crystals, shouldn't you get something resembling what you would get for powder diffraction?
Zz.
This is just a guess, but if the material is really *nano*crystalline, could the pattern be quite different from a normal powder diffraction? I've seen some scanning electron microscopy images of materials which looked like they consisted of >20% grain boundaries, and I am not sure if the grains even all had the same crystal structure...
To OP: I think you might want to ask if someone has a SEM around to take a look at your sample. Material-science SEMs often also have both back-scatter electron differaction detectors and local x-ray-detectors, both of which could tell you exactly what you are looking at (if it is not already obvious by looking at it, I mean).
That is certainly a strong possibility, especially if, as you said, a substantial portion of it is grain boundaries. I have no info if these nanocrystal are of the same structure or not.
But aren't the EDX/EDS from SEM typically tells you the specie of the material, rather than being able to distinguish the crystal structure?
Zz.
Right, SEM EDX is only good for identifying the elemental composition of the grains. However, electron back-scatter diffraction (EBSD) provides a diffraction pattern which can be used to determine the orientation, lattice type, and lattice spacing of the grains. Together with the elemental composition (might be important if there is phase separation) this should allow for a reasonably good guess of what the grains are.
For these techniques, spatial resolution might be a problem for really small grains, though. While with secondary electrons imaging about 1--2nm resolution is possible on a good day with a modern (expensive) SEM, I guess EBSD and EDX might be limited to 5-20nm resolution (but I am not an expert on this).
Black Nova said:
Hi!
Have a nice day
:smile:
It will be difficult to determine the structure in your thin film using the standard Bragg-Brentano geometry for the following reasons:
1) This scattering geometry will only probe the electron density normal to the surface, i.e., you will only see diffraction from lattice planes (roughly) parallel to the substrate. The wavevector transfer, Q, extends normal to the surface as you increase θ-2θ.
2) The penetration depth of the X-rays. With an incident angle much greater than say θ = 1deg (dependent on sample, X-ray λ etc.) the penetration of the X-rays into the substrate becomes extremely high so your diffractogram will be dominated by scattering/diffraction from the substrate.
The solution to this is to use grazing-incidence X-ray diffraction. In this geometry you have the incident X-rays at a fixed incident angle θ, which is normally very small (θ < 1deg). This allows the scattering to arise only from your thin film and not from the substrate. In combination with a 2D detector (or by scanning a point detector vertically and horizontally) you are able to observe the in-plane and out-of-plane Bragg reflections. This technique is more complicated than standard XRD as the small incident angle gives rise to complicated refraction and reflection effects but it is the best way to get information on thin films.
It also usually requires a synchrotron source or a very good specialized lab source so sorry if you don't have access to these!
Hope that helps.
You can use the Scherrer equation to estimate the grain size.
http://en.wikipedia.org/wiki/Scherrer_equation
Tom is right that signal/noise is going to be a problem, and that a grazing incidence geometry will maximize the
signal from your film compared to the background from the bulk substrate. Another way of optimizing the signal
is to use low-energy x-rays that penetrate less deep into the substrate.
  • · Replies 0 ·
9K
