Is my solution of time-dependent Schrodinger equation right?
The discussion revolves around the solution to the time-dependent Schrödinger equation with a time-dependent Hamiltonian. Participants explore the implications of a Hamiltonian that changes abruptly at a specific time and whether the proposed solution accurately describes the system's evolution. The scope includes theoretical considerations and mathematical reasoning related to quantum mechanics.
  • The initial post presents a solution to the Schrödinger equation, asserting that there are no transitions from the eigenstate |n⟩ due to the form of the Hamiltonian.
  • Some participants agree with the solution, stating it is valid and can be verified by substituting it back into the differential equation.
  • Others challenge the solution, arguing that the abrupt change in the Hamiltonian (the "jump function") complicates the situation and may invalidate the proposed solution.
  • A participant suggests that the correct approach involves perturbation theory, applicable only under certain conditions (when the perturbation is small).
  • Concerns are raised about the implications of the Hamiltonian's discontinuity and whether it can be treated as well-defined at all times.
  • There is a discussion about the nature of the time evolution operator and whether it can be expressed as a simple matrix exponential in this context.
  • Some participants question the validity of statements regarding the commutation of Hamiltonians at different times during the "jump" interval.
  • Clarifications are sought regarding the interpretation of the differential equation in the context of the discontinuity.
Participants express differing views on the validity of the proposed solution, with some supporting it and others arguing against it based on the implications of the Hamiltonian's discontinuity. The discussion remains unresolved, with competing perspectives on the nature of the solution and the applicability of perturbation theory.
There are limitations regarding the assumptions made about the Hamiltonian's behavior during the discontinuity and the conditions under which perturbation theory applies. The discussion highlights the complexity of defining operators in the presence of abrupt changes in the Hamiltonian.
extranjero
The problem looks very simple. We have a time-dependent Hamiltonian:
$$H(t) = B(t)H_0$$,
where ##B(t)## is a numerical function, and matrix ##H_0## is time-indpendent.
Let us consider:
$$B(t) = \begin{cases}
1,&\text{for $0\leq t\leq t_0$}\\
A,&\text{for $t>t_0$.}
\end{cases}$$
Also, let us consider that ##H_0## has an eigenstate ##|n\rangle## :
$$ H_0|n\rangle = \varepsilon_n |n\rangle$$.
The problem is to find solution ##|\psi(t)\rangle## of the Schrödinger equation
$$i\frac{\partial}{\partial t}|\psi(t)\rangle = H(t)|\psi(t)\rangle ,$$
when ##|\psi(0)\rangle = |n\rangle##.
My solution is:
$$|\psi(t)\rangle = e^{ -i\varepsilon_n\int_0^t B(t')dt'}|n\rangle$$
So, there are no transitions to other levels from the ##|n\rangle## state.
Some people disagree with me because of "jump function makes exact solution not possible".
Is my solution right or not?
Thanks!
Your solution is fine.
What "people"?
Thanks.
Orodruin said:
What "people"?
Moderator note: links to external debate removed
(It makes no sense to discuss on two different forums simultaneously. If you like, you can insert the arguments against your solution manually, such that we have a common basis for discussion without switching forums. However, since the author of these arguments isn't available to defend them, it likely will end nowhere.)
This is the "argument" against my solution:
Well, I think, that a simple expression demonstrated by Pavel Pyshkin on his picture cannot be an exact solution of this problem in general case, i.e. at arbitrary value of A .
Instead, correct solution of this problem is possible only in the lowest orders of Perturbation theory, for weakly perturbed Hamiltonians only, i.e. when V=(A-1)H_0 << H_0 (or simply when (A-1)<<1).
The form of such a perturbative solution should be following:
U_app(t)={1 - i (V t / hbar) - (1/2)(V t / hbar)^2} U_0(t) (1)
being valid only for times t< t_un, where the minimal quantum "time/energy" uncertainty time for this system is: t_un=(hbar / V)
(here "hbar" - means Planck constant)
and: V=sum_n{ <nIVIn> }=sum_n{ (A-1)E_n } is the small matrix element (of the Hamiltonian perturbation) with (A-1)<<1 and with E_n and In> - being eigenvalues and eigenvectors of "unperturbed" Hamiltonian H_0
also in (1) : U_0(t) =exp{-i H_0 t / hbar} is a "free" propagator of the system with unperturbed Hamiltonian H_0 .
The reasons behind this perturbative solution are following:
1) In the opposite (non-perturbative) limit: V=(A-1)H_0 >> H_0 - all high-order terms in Dyson series for the exact evolution operator of given quantum system - would diverge due to the time region of "big leap" of the system's Hamiltonian in all time-integrations in all high (i.e. >2) orders of Dyson series. Hence, exact solution of the problem would diverge in that non-perturbative limit as well.
2) Pavel's expression presumes definite peculiarities of quantum system's time evolution (like leaps on wave function time-derivative time dependence) which seems to be unphysical for any unitary quantum evolution, since such "evolution peculiarities" represent fingerprints of projective measurements- and wave-function collapse phenomena - which all cannot be described exactly within quantum-mechanical unitary dynamics.
3) Perturbative solution (1) means rather a sort of "quench"- or "tunneling" physics in this case of sudden and sharp Hamiltonian changes (i.e. the situation when the system slowly "tunnels" with time from its "old" unperturbed quantum state to its "new" perturbed quantum state) than a simple fully determined unitary evolution of a closed quantum system, as it follows from Pavel's expression.
4) Even in the perturbative limit when (A-1)<<1, Pavel's expression doesn't fulfill correct time-reversal symmetry of time-dependent Schroedinger equation which should hold in this case seprately in time domain "before" Hamiltonian leap (when Hamiltonian is constnant and equal to H_0) and in the domain "after" the leap (when Hamiltonian is also constant but equal to H=AH_0). This is because Pavel's expression contains a step-like function B(t) under the time integral . Such fuction being integrated over the full time interval of system's evolution (from 0 to t) is not invariant under the time-reversal.
Instead, a perturbative solution (1) fulfills (since it is a perturbative solution) the required time-reversal dynamics separately before and after the Hamiltonian leap.
It is a simple matter of inserting your solution and checking that it satisfies the appropriate differential equation.
In general when you have a Hamiltonian that does not commute at different times, you will not get the solution
\lvert \psi(t)\rangle = e^{-i\int_0^t H(t') dt'} \lvert \psi(0)\rangle,
but a time ordered exponential. In your case, the Hamiltonian at different times commute and your solution is fine. In this case, perturbation theory has nothing to do with it, the solution is exact - as can be checked by simply plugging it into the differential equation. However, if you do apply perturbation theory, the series is convergent everywhere (not only for small deviations) and converges to ... your solution.
This is simply false. The Dyson series is the series of a simple matrix exponential in your case. I would strongly doubt the expertise of the person who wrote this.
Orodruin: "..In your case, the Hamiltonian at different times commute.." and "..The Dyson series is the series of a simple matrix exponential in your case.."
- Are You sure these two statements indeed take place in the "leap" time interval where even such quantity as Hamiltonian of quantum system - is undefined ? (Remark: we are talking here about B(t) as a true step-function not as something regular which can turn into step-function only in a certain limiting case.)
Yes. There really is nothing strange going on here. The Hamiltonians at arbitrary times commute which makes te system's time evolution trivial. It is like solving an ordinary differential equation with the same type of inhomogeneity.
You can chose to interpret the differential equation in a distributional sense at the jump if you must. It does not change the argumentations.
Orodruin: "It is like solving an ordinary differential equation with the same type of inhomogeneity" - But on the leap (or "jump" ) time interval You cannot define any operator, meaning all related things such as matrices, commutation relations..
Orodruin: "You can chose to interpret the differential equation in a distributional sense at the jump" - Please, specify what do You mean by this concerning this particular case?
What time interval is that? The Hamiltonian is well-defined for all times ##t##. It has a "jump discontinuity" in its value, but that doesn't mean there is any value or "interval" of ##t## where it is undefined.
PeterDonis: "..The Hamiltonian is well-defined for all times t.." - It seems, if so, (and if definite causality law connects system's state at the moment "t" with its state at the moment "t+dt") then You should be able, at least, to write down such connection for Hamiltonian, or simpler, just for function B(t), i.e. the connection between B(t) and B(t+dt). Usually, one can do that by using differential i.e. in the form: B(t+dt)=B(t) + (dB(t)/dt)dt , but, how do You think, what meaning has quantity: (dB(t)/dt)dt - when t=t_0 ? - I think the differential of the function B(t) (and, hence, Hamiltonian) is undefined at the point t=t_0 since at this point derivative (dB(t)/dt) - diverges whereas the smallness of "dt", in general , isn't connected with the grade of (dB(t)/dt) divergence at t=t_0. That is why, I think, the infinitesimal interval "dt" "around" the value t=t_0 - represent the interval of function B(t) (and Hamiltonian) uncertainty.
I am sorry, but what you are saying does not make much sense at all. ##B(t)## does not have to be differentiable in order to integrate it - it needs to be integrable. The important thing is not ##(dB/dt)dt## (even if that is perfectly well defined in a distributional sense), it is the integral of ##B(t)##.
If you are unfamiliar with distributional derivatives, you probably should not be replying to an A-level thread. Regardless, they are not necessary here - the function ##B(t)## is integrable. In fact, it does not matter what value it takes at a single point with measure zero, what matters is its integral (or in the case of Hamiltonians that do not commute at different times, the time-ordered exponential).
To be concrete, the time evolution of a general quantum system from time ##0## to ##t## is given by the unitary operator
S(t,0) = \mathcal T e^{-i \int_0^t H(\tau) d\tau},
where ##\mathcal T## denotes time ordering. In this case, time ordering is irrelevant since ##[H(\tau),H(\tau')] = 0## and therefore
S(t,0) = e^{-iH_0 \int_0^t B(\tau)d\tau}.
Note that the Hamiltonian's value at any particular time is not relevant for the time-evolution of the system, only its time ordered integral is. What you are saying is essentially the equivalent of claiming that
\int_0^t B(\tau) d\tau
does not have a definite value for ##t > t_0##.
Also, please use the quote feature. Your posts are unnecessarily difficult to read.
  • · Replies 19 ·
