Undergrad Is My Summary of the Work-Energy Theorem Accurate?
  • Thread starter Thread starter pkc111
The discussion focuses on the work-energy theorem and its application in mechanics, clarifying that forces do not need to be parallel to velocity to perform work, as long as they have a non-zero component in that direction. The work-energy theorem is presented as a general principle applicable to all forces, emphasizing that it remains valid even when no work is done. The conversation highlights the significance of conservative forces, which depend on a potential field, allowing for energy conservation across trajectories without needing specific solutions to equations of motion. The relationship between kinetic energy, potential energy, and total energy is established, reinforcing the concept of energy conservation in mechanical systems. Understanding these principles is crucial for solving problems in mechanics effectively.
pkc111
This is my latest attempt at trying to summarise but I feel there maybe a mistake in the wording. Any help would be appreciated.
Thanks.
why do you think the forces need to be parallel to the velocity?
Every force has to have a non-zero component parallel to the motion to contribute to work in that direction
ie W=Fscostheta.
yeah, exactly - a force doesn't need to be parallel to the velocity to do work
Likes vanhees71
Ok then does it sound better to replace "parallel" with "which have a component that is parallel"?
Likes vanhees71
The work-energy theorem is valid for any combination of forces. It is the most general relationship and not a special case. Conservation of energy does not apply always but w-e theorem does.
Likes vanhees71
ie W=Fscostheta.
The W-E theorem remains perfectly valid even when the work is zero. You could argue that is just as important a case as when the KE is changing.
The work-energy theorem holds for all forces, and one should always use vectors for derivations in mechanics not to get confused with directions of the involved quantities. As the most simple case we consider a single point particle moving under the influence of an arbitrary external force:
$$m \ddot{\vec{x}}=\vec{F}(t,\vec{x},\dot{\vec{x}}).$$
You get the work-energy theorem by assuming that ##\vec{x}(t)## is an arbitrary solution of this equation of motion. Then
$$m \dot{\vec{x}} \cdot \ddot{\vec{x}}=\dot{\vec{x}} \cdot \vec{F}[t,\vec{x}(t),\dot{\vec{x}}(t)].$$
The left-hand side is a total time derivative, because
$$m \dot{\vec{x}} \cdot \ddot{\vec{x}}=\mathrm{d_t}(m \dot{\vec{x}}^2/2)=\mathrm{d}_t T,$$
where ##T=m \dot{\vec{x}}^2/2## is the kinetic energy. Plugging this in the above equation and integrating over some time interval you get
$$T_2-T_1=\int_{t_1}^{t_2} \mathrm{d} t \dot{\vec{x}}(t) \cdot \vec{F}[t,\vec{x}(t),\dot{\vec{x}}(t)]=W_{12}.$$
The right-hand side is called work.
This law is not very helpful as it stands, because you need to know a solution of the equations of state. So it's just a nice observation to hold for any such solution, but it doesn't help much to find a solution.
This changes drastically for the special case that the force has a potential. Then the force shouldn't depend on time and velocity and there should be a scalar field ##V(\vec{x})## such that
$$\vec{F}(\vec{x})=-\vec{\nabla} V(\vec{x}).$$
Plugging this into the work-energy theorem you get
$$T_2-T_1=W_{12}=-\int_{t_1}^{t_2} \mathrm{d} t \mathrm{d}_t V[\vec{x}(t)]=-[V(\vec{x}(t_2))-V(\vec{x}(t_1))]$$
or
$$T_2+V(\vec{x}(t_2))=T_1+V(\vec{x}(t_1))=E.$$
This means that in this case for any trajectory the total energy ##E=T+V## is conserved, i.e., it doesn't change with time.
The important twist now is that ##W_{12}## does not depend on using the solution of the equation of motion to calculate the corresponding line integral, because if the force has a potential, then you can use any line connecting two points ##\vec{x}_1## and ##\vec{x}_2##. You always get
$$W_{12}=-[V(\vec{x}_2) -V(\vec{x}_1)],$$
i.e. you know without the solution of the equation of motion how energy conservation looks, and it can indeed help to find solutions of the equation of motion and that's why we call forces which have a scalar potential in the above given sense "conservative", i.e., you don't only have the work-energy theorem but the theorem of energy conservation, i.e.,
$$E=T+V=\text{const}##
along any solution of the equations of motion.
  • · Replies 21 ·
  • · Replies 31 ·
  • · Replies 77 ·
  • · Replies 75 ·
