Is normal derivative a definition?
The discussion centers on the interpretation of the normal derivative, specifically the expression ##\frac{ \partial f}{\partial n} = \nabla f \cdot \hat n##. Participants confirm that this expression represents the rate of change of a function in the direction of the normal vector ##\hat n##, which is associated with a curve or surface. The divergence theorem is referenced to validate the equivalence of the integrals presented, emphasizing that ##v## is a function relevant to the context of the volume integral ##dV##. The consensus is that ##\frac{ \partial f}{\partial n}## is indeed a definition, clarifying its mathematical significance.
  • Understanding of vector calculus, particularly gradients and normal vectors.
  • Familiarity with the divergence theorem and its applications.
  • Knowledge of integral notation and volume integrals.
  • Basic concepts of directional derivatives in multivariable calculus.
  • Study the properties of normal vectors in vector calculus.
  • Explore the divergence theorem and its implications in physics and engineering.
  • Learn about directional derivatives and their applications in optimization problems.
  • Investigate the relationship between partial derivatives and gradient vectors in multivariable functions.
Mathematicians, physics students, and engineers who require a deeper understanding of vector calculus and its applications in analyzing functions with respect to normal directions.
yungman
Is ##\frac{ \partial f}{\partial n} = \nabla f \cdot \hat n ## a definition? No article that I found said it's a definition. The term ##\frac{ \partial f}{\partial n}## does not make sense to me, what is ##\partial n##?
Also is this correct:
\int_v\nabla\cdot (v\nabla u)dV=\int_s (v\nabla u)\cdot \hat n dS=\int_s v(\nabla u\cdot \hat n) dS=\int_s v\frac {\partial u}{\partial n} dSThanks
Thanks
Well, what is ##\hat n##? I would interpret that as the normal vector to some curve (in two dimensions) or surface (in three dimensions), but you don't mention a curve or surface. Assuming there is such an object, then I would interpret the notation ##\frac{\partial f}{\partial n}## as the rate of change of f in the direction perpendicular to that curve or surface. That is, of course the same as \nabla f\cdot \hat n but I would say you can reasonably take either as a definition of the other.
Thanks for the reply. Yes, ##\hat n## is the normal of the boundary. Here is an article contains normal derivative.
http://en.wikipedia.org/wiki/Directional_derivative
I am almost sure it's a definition, but this is math, it's black and white.
Thanks
This makes sense, simply the divergence theorem, I assume v is some other function, but you say you integrate over it in your first expression, I think that is meant to be a capital V, correct?
\frac{\partial f}{\partial n}=\nabla f \cdot \hat n
Take this as you will, the last poster confirmed that it is true and it makes sense to me as well.
My bad, I should have use a different variable name. ##v## is a function of the same coordinates as the ##\nabla## and ##dV## is volume integral.
It is a definition of what the short-hand notation df/dn is meant to signify, i.e, an identity, not some equation or perceived relationship between (otherwhere defined) LHS and RHS.
Thanks.
  • · Replies 16 ·
