Is Resistance Inversely Related to Gradient in a Filament Bulb?
The discussion revolves around the relationship between resistance and gradient in a filament bulb, specifically questioning if they are inversely related. The original poster seeks clarification on how to explain this relationship using a curved graph, contrasting it with the linear relationship seen in nichrome wire. Participants confirm that resistance can be calculated using voltage and current, and suggest that the inverse relationship holds true when considering the gradient of the graph. There is also a mention of the need to clarify whether the resistance is being analyzed for small changes. The conversation emphasizes the importance of understanding the graph's implications for resistance in filament bulbs.
mani18
need an urgent help on filament bulb topic
hi everyone
i am getting stuck in this assignment on question related to filament bulb.
the question goes like: is resistance and gradient inverse to one another in filament bulb and when looking at the graph (which is a curve graph)..
we need to explain on how
i could do it for nichrome wire since it had a straight line.
if you could jus tell me on how to show it and brief explanation i would be very grateful.
cheers
mani
gradient of what ?
sorry for being clear. hope this one will be clearr enough.
graph is used to calculate the gradient so the question asks can you find the resistance using 1/m (1/gradient) n r they inverse to one another
I would say yes. Can you post the graph ?
okay thank you. here you go.
Yes sure, you can always calculate R given V and I.
The only doubts is if you want the resistance for small changes or not.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
