Is result of vector inner product retained after matrix multiplication?
The discussion revolves around the properties of the inner product of two vectors after they have been transformed by a matrix. The original poster considers whether the inner product remains positive when two vectors, initially pointing in similar directions, are multiplied by a matrix with real entries.
  • Exploratory, Assumption checking
  • The original poster attempts to reason through the transformation of vectors and their inner product, suggesting that similar vectors should remain similar after transformation. They express uncertainty about the conditions under which the inner product remains positive.
  • Some participants question the implications of linear independence of the vectors and whether a linear transformation can be found that maintains the inner product's positivity.
  • Counterexamples are proposed to challenge the assertion, particularly focusing on specific vector pairs and transformations.
The discussion is active, with participants exploring different scenarios and questioning the validity of assumptions regarding the inner product after transformation. Some guidance has been offered regarding the conditions under which the inner product may not remain positive, but no consensus has been reached.
Participants note that the behavior of the inner product may depend on the properties of the transformation matrix and the relationship between the vectors, particularly in cases of linear independence.
Master1022
Let us imagine that we have two vectors ## \vec{a} ## and ## \vec{b} ## and they point in similar directions, such that the inner-product is evaluated to be a +ve number. If we now multiply both of the vectors by a matrix ## W ## which has real entries, will the inner product of the 'transformed' vectors also be positive?
Inner product
Hi,
I was thinking about the following problem, but I couldn't think of any conclusive reasons to support my idea.
Question:
Attempt:
Intuitively I think along the lines of: if we imagine the operation as transforming a vector in some way, then the two vectors ## \vec{a}## and ## \vec{b}##, which were similar, should be transformed to similar vectors?
Mathematically, I can write the following:
[tex]<W \vec{a} , W \vec{b} > = (W \vec{a}) \cdot (W \vec{b}) = (W \vec{a})^{T} (W \vec{b}) = \vec{a}^{T} W^{T} W \vec{b}[/tex]
- ## W^{T} W ## is positive semi-definite.
- I suppose if ## \vec{a} ## and ## \vec{b} ##, then if/how positive the outcome will depend on some type of sensitivity of ## W ##? That is, we could view ## \vec{b} = \vec{a} + \vec{\epsilon} ## and think about that?
Any help is greatly appreciated.
If ##\vec a## and ##\vec b## are parallel, then the assertion follows directly from ##W^T W## being positive semi-definite (as long as you change the statement to be non-negative instead of positive - it should be pretty obvious that the result can be zero if ##W^T W## happens to have eigenvalues that are zero, such as when ##W = 0##).
However, consider what happens when you let ##\vec a## and ##\vec b## be linearly independent and ask yourself the following questions:
  • Taking any set of two vectors ##\vec c## and ##\vec d##, can you find a linear transformation ##W## such that ##W\vec a = \vec c## and ##W \vec b = \vec d##?
  • What does this mean for your assertion?
Thanks for the reply @Orodruin !
Agreed
I think so... I could imagine forming some matrix equation like:
[tex]W [ \vec{a} \quad \vec{b}] = [\vec{c} \quad \vec{d}][/tex]
and if ## \vec{a} ## and ## \vec{b} ## are linearly independent, then the matrix is full-rank and that can be inverted to find ## W ##.
That might suggest that the outcome of the transformed inner product is still positive? This doesn't necessarily seem correct, but I am confused still...
It took me about 30 seconds to find a counterexample. Hint. Let the vectors be ##(1,0)## and ##(1, 1)##. Look for a 2 x 2 matrix that maps ##(1, 0)## to itself and ##(1, 1)## to something in approximately the opposite direction.
So you are free to choose any ##\vec c## and ##\vec d##. Are there any such pairs with a negative inner product?
Okay thanks @PeroK ! That makes sense, and yes I can see how the answer to my question was 'not necessarily'.
  • · Replies 58 ·
