Is the CO amount I found correct?
  • Thread starter Thread starter chemman218
The problem involves calculating the carbon monoxide (CO) emissions from an automobile based on its exhaust rate and concentration of CO in the exhaust. The subject area includes gas laws and emissions calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculations related to the flow rate of CO and its conversion to grams per kilometer. There are questions regarding the assumptions of standard temperature and pressure (STP) and the accuracy of the initial flow rate used in the calculations.
The discussion is ongoing, with participants providing feedback on the calculations and clarifying assumptions about the conditions under which the measurements are taken. Some participants have pointed out potential errors in the initial calculations and have engaged in verifying the conditions for STP.
There is a mention of specific conditions (1 atm and 298K) that were instructed by the teacher, which may differ from standard definitions of STP. Additionally, there is a correction regarding the percentage used in the calculations, indicating a need for careful attention to detail in the problem setup.
chemman218
An automobile traveling 50 Km/hr emits 0.1% CO from the exhaust. If the exhaust rate is 80 m^3/min, what is the CO emission in grams per kilometer?
PV=nrt
flow rate volume of CO =(.8m^3/min)8(1min/.833km)=.960m^3/km*(1000L/1m^3)=960 L/km
PV=nRT
n=((1atm)(960L/km))/((.08206 L*atm/mol*k)*(298K))=39.25 moles/km of CO
39.25moles/km * 28g/mole of CO = 1099.65 g/km
Yes, assuming that those 80 m^3/min are specifically referenced to 1 atm and 298K.
Chet
Yes, it is at STP. I was trying to search the internet for reference on CO levels from automobiles to see if the number I got was correct but could not find anything. Thank you for your help!
Isn't STP 1 atm and 0 C?
Chet
Yes you are correct, but our teacher told us to use 298K.
Shouldn't that be 0.08 m3/min if it's 0.1% of 80 m3/min?
Thank you for the catch. I used the wrong percent to multiply. I used .01 instead of .001. Thank you so much for all your help!
12K
