Undergrad Proving the Linearity of the Curl Operator in Electromagnetic Theory
The discussion centers around the linearity of the curl operator in electromagnetic theory, particularly in relation to Maxwell's equations, which are linear. Participants debate the mathematical proof of the curl's linearity and clarify that linearity is a consistent property across mathematical contexts, despite its various applications. The conversation highlights confusion regarding the term "linear solution" and emphasizes that linearity refers to the rules of addition and scalar multiplication applicable to operators. A participant requests further clarification on proving the linearity of the curl operator, indicating ongoing exploration of the topic. Overall, the thread underscores the importance of understanding linearity in the context of electromagnetic theory and mathematical operations.
Sheldon Cooper
Hi,
I stumbled upon thinking that "Is curl operator a linear operator" ?
I was reading EM Theory and studied that the electromagnetic field satisfies the curl relations of E and B. But if the operator was not linear then how can a non linear operator give rise to a linear solution. Thus it becomes apparent that curl is linear but how can we prove it mathematically?
Thanks in advance.
Use the definition ##\displaystyle (\vec \nabla \times \vec F)\cdot \hat n \equiv \lim_{A_n\to 0} \frac{1}{A_n} \oint_{\partial A_n} \vec F \cdot \vec{dr} ## (where ##A_n## is a surface with unit normal ##\hat n## and ##\partial A_n ## is its boundary curve.)!
Does an operator have to be linear to generate a linear solution to an arbitrary equation, I did not know that??
A proof for the general case?
houlahound said:
Does an operator have to be linear to generate a linear solution to an arbitrary equation??
The phrase "linear solution" seems meaningless to me. Linearity is a property of an operator/equation.
I can't get the question, linear has multiple meanings in math.
The OP has realized that Maxwell's equations are linear equations and so the curl operation is linear too. He just wants to prove that it actually is.
Which are? You can have linearity on the objects ##O## or in the arguments ##A##, but it's always the same condition:
Linear can mean supper position, straight line, type of vector space , something raised to power one, a type of DE...
Which are all together just linear combinations of certain objects, or linear in the argument in case of scalar multiplication.
However, I have not the slightest idea what "type of vector space" means. Vector spaces are per definition a set of linear combinations.
There is no "multiple meaning" of linearity in math.
Correction type of space eg vector space.
How is a linear equation eg y=2x+1the same as a linear first order DE or a linear operator?Linearity has context.
This is no linear function. It's called an affine transformation. To call it "linear" isn't exact. ##y(0) ≠ 0##
It is linearity on the considered objects, here differential operators which are a special case of linear operators.
Wrong. The objects or arguments it applies to have a context, e.g. the derivatives in the example above.
Linearity itself is a property independent of what you regard in a special case, it simply says that you have a rule for addition and for scalar multiplication - whether it's applied to a superposition or an operator. The meaning of "linear" does not change.
I learned something, thanks.
Hey Shyan, tried your procedure to prove the linearity problem but and am stuck can u please add a few more steps(if possible).
Just put ## \vec F=\vec G+b \vec H ## in the definition!
ok got it thanks!
  • · Replies 21 ·
