Is the derived set closed in a metric space?
  • Thread starter Thread starter jdstokes
    Closed Set
9 replies · 12K views
jdstokes
Hi all,
Would anyone be able to comment if my proof is sound or can be simplified.
Let (X,d) be a metric space, A a subset of X. The derived set A' of A is the set of all limit points of sequences in A.
Proposition: A' is closed.
Proof: Show that its
complement is open. Let [itex]x\in X\backslash A'[/itex] Then [itex]x\not\in \overline{A}[/itex] so there is a
non-zero [itex]\varepsilon_x[/itex] s.t. [itex]B(x,\varepsilon_x) \cap A = \emptyset<br /> \Rightarrow B(x,\varepsilon_x) \subseteq X \backslash A[/itex]. Suppose
[itex]\exists y \in B(x,\varepsilon_x)[/itex] which in addition belongs to
A'. Then there's an open ball [itex]B(y,\varepsilon_y) \subseteq<br /> B(x,\varepsilon_x)[/itex] about y which intersects A. Then
[itex]B(x,\varepsilon_x) \cap A \neq \emptyset[/itex]. This contradiction shows
that [itex]B(x,\varepsilon_x) \subseteq X\backslash A'[/itex]
Please correct me if I'm wrong, but as far as I can see, [tex]A'=\overline{A}[/tex] !
Now that I think about it, it seems like you are correct. Since surely [itex]A' \supseteq A[/itex]. When I look at my lecture notes/lectures however, the define
[itex]\overline{A} = A \cup A'[/itex].
Are there any counterexamples where [itex]A' \neq \overline{A}[/itex]?
Ahh yes.
Now that I think about the definition of A', it is not always true that [itex]A'\supseteq A[/itex] since the definition of A' requires that for each x in A there by a point, a ,NOT EQUAL to x s.t. d(x,a) < epsilon for all epsilon > 0.
[itex]A' \supseteq A[/itex] will fail for any discrete space.
I don't understand your last two posts.
Is it true or not that
If so, then we can show that every point in [itex]A'[/itex] is in [tex]\overline{A}[/tex] and vice versa. Firstly, observe that [tex]\overline{A}=A\cup \mbox{Acc}(A)[/tex] (Acc(A) being the set of all accumulation points of A).
Let x be in A'. If x is in A, then x is in the closure also. If not, then x is obviously an accumulation point of A, so x is in the closure again. This shows that [tex]A'\subset \overline{A}[/tex].
Now let x be in [tex]\overline{A}[/tex]. Then x is in A or in Acc(A). If x is in A, then define the constant sequence x_n=x. So x is in A'. If x is in Acc(A), then it is also easy to find a sequence of elements of A converging to x, so that x is in A' again. This shows that [tex]\overline{A}\subset A'[/tex].
So it must be that [tex]A'=\overline{A}[/tex].
The word limit point and accumulation point are equivalent in the course I'm taking. You cannot claim that x is a limit point because it is the limit of the constant sequence {x,x,...}.
If you take the discrete space consisting of just two points, say. Then no point in the space is an accumulation point/limit point.
It is of course true that [itex]A' \subseteq \overline{A}[/itex] since [itex]\overline{A} = A \cup A'[/itex].
I now think my original post is in error because [itex]x\not\in A' \not\implies x\not\in \overline{A}[/itex].
Do you have any suggestions on how to correct this?
thanks
James
To show Acc(A) is closed, show that a sequence of points in Acc(A) lies in Acc(A).
I'm sure you meant to write:
To show Acc(A) is closed, show that if a sequence of points in Acc(A) converges to a limit, then the limit lies in Acc(A).
The typical example is:
[tex]A=\{ \frac{1}{n} \}[/tex]
[tex]A'=\{ 0 \}[/tex]
Yes. :smile:
