Is the Function Analytic and Where?
  • Thread starter Thread starter squaremeplz
squaremeplz
Determine if the function is analytic and sketch where it's analytic.
a) [tex]f(x) = \frac {e^z}{z^2 + 4}[/tex]
b) [tex]f(z) = \frac {conj(z)}{|z|^2}[/tex]
c) [tex]\sum_{n=0}^\infty \frac {e^z}{3^n} (2z-4)^n[/tex]
a) [tex]e^z[/tex] is analytic everywhere so [tex]f(x) = \frac {e^z}{z^2 + 4}[/tex] is analytic everywhere except at
[tex]z^2 = (x + yi)^2 = -4[/tex]
I tried separating the function into [tex]f(x,y) = u(x,y) + i*v(x,y)[/tex] but get a very complex polynomial when I try to get rid of the imaginary part in the denominator for example:
[tex]\frac {e^x (cos(y) + i*sin(y)}{(x+yi)^2 + 4} * \frac{(x-yi)^2 + 4}{(x-yi)^2 + 4}[/tex]
does not work for me
b)
[tex]f(z) = \frac{conj(z)}{ |z|^2}[/tex]
[tex]f(z) = \frac{1}{z}[/tex]
[tex]\frac{1}{z} = \frac{1}{ x+yi}[/tex]
[tex]\frac{x - yi} {x^2 + y ^2}[/tex]
[tex]= \frac{x}{x^2 + y ^2} - \frac {yi}{x^2 + y ^2}[/tex]
[tex]since \frac{du}{dx} u(x,y) = \frac{dv}{dy} u(x,y)[/tex]
and [tex]\frac{dv}{dx} u(x,y) = - \frac{dv}{dx} u(x,y)[/tex]
the function is analytic everywhere except at the origin.
d) After using the ratio test, the result I get is
[tex]|\frac{1}{3} (2z - 4) |[/tex]
[tex]\frac {1}{3} |2z - 4|[/tex]
so the function is analytic on the disk [tex]0 < |2z - 4| < 6[/tex] for all values n
Right, so [itex]f(z)[/itex] is analytic everywhere except at [itex]z=\pm2i[/itex]
I'm not sure why you'd want to do it this way, since you've already found the answer using a much easier method, but if you want to be a masochist about it, this method should work fine as well.
[tex]\left[(x+yi)^2 + 4\right]\left[(x-yi)^2 + 4\right]=(x+iy)^2(x-iy)^2+4(x+iy)^2+4(x-iy)^2+16=(x^2+y^2)^2+8(x^2-y^2)+16[/tex]
and so on...
You mean, "since [itex]\frac{\partial u}{\partial x}=\frac{\partial v}{\partial y}[/itex] and [itex]\frac{\partial u}{\partial y}=-\frac{\partial v}{\partial x}[/itex] except at the origin, where [itex]u[/itex], [itex]v[/itex] and their partial derivatives do not exist, the function is analytic everywhere except at the origin", right?
Where is the '6' coming from?
