Is the function differentiable at x = p?
  • Context: Undergrad
  • Thread starter Thread starter PcumP_Ravenclaw
    Differentiable Function
5 replies · 2K views
PcumP_Ravenclaw
Hello mates,
is the function ## f(x) = \frac{(2^x - 1)}{x} ## differentiable at x = 0? For it to be differentiable it has to be continuous? From the graph f(0) is undefined although limit exists. I have read that at points like a corner, gap and vertical tangents it is not differentiable. So why is it differentiable at f(0)?
Sehr Danke!
Quotient rule:
if ##f(x) = g(x) / h(x)##, ##g(x) = 2^x - 1## and ##h(x) = x## then ##f'(x) = (h(x) * g'(x) - g(x) * h'(x) / g(x)^2##. In this case, ##g(x)^2 = 0## so the derivative would be undefined. Does this help?
PcumP_Ravenclaw said:
Hello mates,
No.
This function isn't defined at x = 0, hence it's not continuous at x = 0, so it can't be differentiable there.
Sehr Danke!
However, ##\displaystyle \ \lim _{x\to0} f'(x)\ ## does exist.
Isaac0427 said:
Quotient rule:
This assumes ## g \neq 0 ## which is not the case, like many said. You may say that _at points where ##g \neq 0 ##_ (since both ## f,g## are everywhere differentiable), you can say ## (f/g)' = \frac {f'g-fg'}{g^2}= \frac {(ln2)(2^x)x -2^x}{x^2} ##, using the identity ## 2^x = e^{xln2}##.
Hello mates,
Sehr Danke!
Functions can only be differentiable where they are actually defined. However the singularity at the origin is removable by setting [itex]f(0) = \ln 2[/itex]. Then the function is not merely differentiable at the origin but analytic, and its Taylor series is [tex] f(x) = \sum_{n=0}^\infty \frac{(\ln 2)^{n+1} x^n}{(n+1)!}.[/tex]
