Is the Iwill QK8S-8P the First 8-Way Opteron Server?
  • Thread starter Thread starter hitssquad
    Server
The discussion centers around the introduction of the Iwill QK8S-8P server and whether it is the first 8-way Opteron server. Participants explore the specifications and configurations of the QK8S and QK8S-8P motherboards, as well as the implications of their designs.
  • Some participants note that Iwill claims to have introduced the first modular 4P and 8P Opteron motherboards using HTX-Pro technology.
  • One participant expresses enthusiasm for the capabilities of the 8-way system, highlighting the potential for increased data processing.
  • Another participant clarifies that the QK8S-8P can hold up to 256GB of RAM, contrasting it with their laptop's 20GB hard drive capacity.
  • A later reply challenges the accuracy of earlier claims regarding the configurations of the QK8S and QK8S-8P, stating that the QK8S is a 4-way system and the QK8S-8P is indeed an 8-way system, correcting the misunderstanding about the number of boards required for each configuration.
  • Participants discuss the RAM capacity of the QK8S-8P, with one emphasizing that it can accommodate 256GB due to its design involving two QK8S CPU boards.
There is disagreement regarding the initial claims about the configurations of the QK8S and QK8S-8P motherboards, with some participants correcting earlier statements without reaching a consensus on the implications of these configurations.
Participants express uncertainty about the specifications and configurations of the motherboards, with some relying on external sources for clarification. The discussion reflects varying interpretations of the technical details involved.
hitssquad
http://www.xbitlabs.com/news/cpu/display/20040405044711.html X-bit labs that at least one system integrator would unleash a server powered by 8 AMD Opteron processors this week. So far server makers have only released 2-way or 4-way systems based on AMD64 chips, while 8-way designs were expected for introduction at a later date.
Computer science news on Phys.org
Mmmm..mmmm mmmm... 8 way goodness. Now I can start pumping more data. :biggrin:
Iwill announces its own 8P Opteron motherboards
From The Inquirer:
  • TAIWANESE SERVER firm Iwill said it has introduced what it claims are the first modular 4P and 8P Opteron mobos using HTX-Pro, which is a Hypertransport expansion capability.
    The boards are the QK8S and the QK8S-8P...
    the QK8S, for example, uses three separate boards to form an eight way system...
    The 8P uses five separate boards to make an eight way system.
And the QK8S-8P can hold up to 256GB of RAM. The hard drive in my laptop I am using right now only holds 20GB.
Your hard drive has nothing to do with RAM. Understand that 256GB of ram is actually RAM, not hard drive space.
Iwill 8P Opteron system correction
hitssquad said:
From The Inquirer:
This is incorrect. The correct figures are: 4-way for the QK8S, and 8-way for the QK8S-8P (and hence the addition of 8P to the name). http://www.rednova.com/news/display/?id=96397 is a link to Iwill's detailed press release which gives much more information than the Inquirer write up:
  • The Iwill QK8S consists of three (3) separate boards to form a complete 4-Way AMD Opteron processor solution...
    The Iwill QK8S-8P consists of five (5) separate boards that form a complete 8-Way AMD Opteron processor solution. By adding a second Iwill QK8S CPU board via our HTX-Pro(TM) interconnect backplane with the first QK8S (3 board set) creates this 8P board set.
    The CPU Board is the core of the QK8S design. It supports four (4) AMD Opteron 800 Series Processors with sixteen (16) DDR SDRAM slots to support up to 64GB of Registered DDR400/DDR333 memory using 4GB modules or 128GB of Registered DDR266 memory using 8GB modules.
This is correct, but as stated above the reason is that the QK8S-8P consists partly of two QK8S CPU Boards and each board can be populated with a maximum 128GB of RAM.
  • · Replies 0 ·
  • · Replies 65 ·
13K
