Is the Limit Point of a Bounded Set Always a Supremum?
The discussion revolves around the concept of limit points in the context of bounded sets in real analysis. The original poster questions whether the supremum of a bounded set is always a limit point, providing a counterexample involving a finite set.
  • The original poster presents a counterexample with a finite set and expresses confusion over the definitions of limit points. Other participants discuss the definitions and implications of limit points, particularly in relation to finite sets and the supremum.
The conversation is ongoing, with participants exploring different definitions of limit points and their implications. Some guidance has been offered regarding the definitions, but no consensus has been reached on the interpretation of the original question.
There is a noted distinction between definitions of limit points, particularly regarding whether limit points must be outside the set. The original poster's counterexample assumes the supremum can be an element of the set, which contrasts with the book's proof that seems to assume it cannot.
lonewolf5999
Hello,
I'm working through an analysis textbook on my own, and came across a true/false question I was hoping someone could help me with. The question is:
If A is a bounded set, then s = sup A is a limit point of A.
I think that the statement is false, as I came up with what I think is a counterexample. Let A = {1,2}, then clearly A is bounded since if a is an element of A, 1 <= a <= 2. Also, sup A = 2. But in an earlier exercise, I proved that finite sets have no limit points, so since A is finite, sup A = 2 is not a limit point of A even though A is bounded.
However, my book claims that this statement is true, and even gives a proof. I can't figure out what's wrong with my counterexample, so I'd really appreciate it if anyone could help me figure out what's wrong here. Thanks a lot!
lonewolf5999 said:
Hello,
Every element of a set is a limit point of the set. It is the limit of the constant Cauchy sequence. what you were probably thinking is that for a finite set there are no limit points outside of it.
I'd agree with you, except that my book also says that x is a limit point of a set A iff there exists a sequence (an) contained in A such that lim an = x, and an =/= x for all n. So this means that when looking for a sequence contained in A converging to x, we're not allowed to consider the constant sequence (an) = x, or a sequence which is eventually equal to x, or any other sequence which has x as an element, which is why a finite set has no limit points.
edit @ below: I hope that answers the question. Any thoughts on my counterexample?
That is not the standard definition of "limit point":
Wikipedia: "Let S be a subset of a topological space X. A point x in X is a limit point of S if every open set containing x contains at least one point of S different from x itself." (emphasis mine)
Using that definition, a finite set cannot have any limit points.
Lonewolf5999, does that text give a definition of limit point?
This seems to be a matter of definition. Your counter example is correct if a limit point must be outside the set. Conceptually you are looking for all points that are limits of Cauchy sequences in the set. I guess you can divide these into those that are inside and those that are outside.
I'll just post the book's answer to this question and see if anyone has any thoughts on this as well.
"Let A be a bounded set, and let s = sup A. Then for any ε > 0, s - ε is not an upper bound, so we can find an element a of A such that a > s - ε. Hence a lies in the ε-neighborhood of s, and so the ε-neighborhood of s intersects A at a point other than s. Hence s is a limit point of A."
I think that this answer makes the assumption that s = sup A is not an element of A itself, but my counterexample doesn't, which is why sup A = 2 is not a limit point in my example. Is this all I need to resolve the difference between my answer and the book's answer?
Yes. If you take the definition that a limit point is not an element of the set, then book's proof is not taking account of that clause in the definition.
Okay, I think that clears up the confusion I had. Thanks for helping me out.
9K
  • · Replies 25 ·
  • · Replies 43 ·
