Is the Riemann Hypothesis Equivalent to S=2Z?
7 replies · 5K views
zetafunction
let be the function [tex]\sum_{\rho} (\rho )^{-1} =Z[/tex]
and let be the sum [tex]S= \sum_{\gamma}\frac{1}{1/4+ \gamma ^{2}}[/tex]
here 'gamma' runs over the imaginary part of the Riemann Zeros
then is the Riemann Hypothesis equivalent to the assertion that [tex]S=2Z[/tex] ??
Yes. What happens if the RH is false? That means the conjugate zeros are off the critical line and symmetric to it (they come in four's in that case and not just two). How would that affect the two sums if that happened?
In other words it is mirrored. If goes up in the uper half, it will be opposite in the bottom half.
The real line is the mirror line.
i got the desired result in
however it seems to good to be true http://vixra.org/pdf/1110.0041v1.pdf
manage to prove that [tex]\sum_{t}(1/4+t ^{2})^{-1}=2+ \gamma -log(4\pi)[/tex]
here 't' runs over the imaginary part of the Riemann Zeros, i have used the Riemann-Weil formula to prove it.
zetafunction
What do you mean by Riemann Zeros?
Non trivial, trivial, or both??
lostcauses10x ..
i mean the imaginary part of the zeros ON THE CRITICAL STRIP [tex]0<Re(s)<1[/tex]
zetafunction
thanks.
Had to give this a bit of thought. Yet when examining the couture relations of the zeta function and the non trivial zeros a relation of the reflection property of the real line also shows up with the relation of the real line with limits due to the intersect of the non trivial zeros. A perpendicular intersect.
It seems to me this relation is directly proportional to the real line, and if the hypothesis is true, this relation is directly proportional and directly related tto the reflection and imaginary parts and perpendicular intersects at the real line.
Were as this limited reflective property appears around the non trivial zeros, were it starts on the real part contour is a bit of a problem to find: even if the hypothesis is true.
Just an observation, yet interesting result of what was said here. It does put the function in a bit better perspective to me. Of course this thought process is just beginning for me.
