DrDon said:
DrGreg, your response brings up a tangent question I hope you (or others) can answer -- a question I don't recall thinking of before. Accepting that I, as an at-rest observer (but "at rest" relative to what?), see a light beam approaching me at c, if I were to towards or away from that beam, would I still see it at c, or at c plus/minus my own velocity?
Have you ever thought about what it means to "see a light beam approaching" you and how you would measure its speed? Has it occurred to you that you cannot see the beam, all you can see is the portion of it when it reaches you? If you're thinking about seeing a beam from a search light, for example, the only reason why you can see it as a beam is because there are dust particles in the air that are illuminated by the beam itself and then scattered in all directions and you're seeing the ones that are scattered in your direction. But if you were in the vacuum of space, you would not see any beam; you would just see the spot where it hits your eye or your detector. It may look like it is coming from a source far away, but you cannot see the image of that source until the light from it reaches you, correct?
So now, how do you measure its speed since you cannot see it until it reaches you? First off, it doesn't matter if you are "at rest" relative to anything, just that you are not accelerating. Secondly, you don't have to worry about any frame of reference or any theory about relativity or ether or anything else. Thirdly, you don't have to worry about the source of light, just that it is not accelerating, which just means that it is not changing.
Now in order to actually measure the speed of light coming from a fixed distant source, you need to have some equipment. Since speed is length divided time, you need to have a rigid measuring stick of a known fixed length and a timing device. Since the beam is coming at you all the time, you also need a shutter so that you can start and stop the beam to give you something to observe and know when the light has traveled a certain distance. One last thing you need is a mirror. So you fix your shutter at one end of your measuring stick along with your timer which you start together. The pulse of light now travels to the other end of your measuring stick where it reflects off the mirror and back to you where you have a light detector that stops the timer. Then you calculate the speed of light as twice the distance between your shutter/detector and your mirror, divided by the time interval. The value that you get will be c.
Now you fire your rockets and head toward the light source until you reach whatever speed you want. You turn off your thrusters and you repeat your measurement exactly as you did before and you get the exact same value for the speed of light.
Now you turn your rocket around and head away from the light source until you are going in the other direction from your first measurement and go as fast as you want. You stop, turn around and repeat the measurement. You get the same answer.
Do you accept this as a factual statement of what would really happen if you could carry out this experiment?
