Is there a better way to find the number of integer solutions
  • Thread starter Thread starter Rijad Hadzic
    Integer
The discussion focuses on finding the number of integer solutions for the equation x1 + x2 + x3 + x4 = 32, with constraints on the variables. The original poster calculates the solutions by considering cases for x4 and adjusting the equation accordingly. There is some confusion regarding the correct interpretation of the constraints, particularly whether x4 can equal 25 or must be less than it. Participants clarify the method and suggest that the original approach is valid but could be presented more clearly. Overall, the solution is deemed correct, but clearer communication of the method is necessary for better understanding.
Rijad Hadzic
# of integer solutions of x1+x2+x3+x4 = 32
where x1,x2,x3>0 and 0<x4≤25
So in the case where x4 = 25 we have
x1+x2+x3= 4
in the case where x4 = 24 we have
x1+x2+x3 = 5
in the case where x4 = 1 we have
x1+x2+x3 = 28so we can do x1+x2+x3+x4 = 28
which will give us f = 31!/3!28!
now we subtract f - g where g =
x1+x2+x3 < 4
(31!/(3!28!)) - (6!/(3!3!))
= 4475
The answer is correct but I don't know if my method is a good one. Can anyone let me know?
Likes Charles Link
That should be by far the easiest approach.
To motivate this a bit (not for you, but for other readers): Imagine 28 written as 28 "1"s with three separators to form four groups: 111|11||11111111111111111111111. Now let x1 be the size of the first group plus one, x2 be the size of the second group plus one and so on. My example corresponds to 32 = 4+3+1+24. There is a one to one relation between the sums and the 1/separator strings. There are (31 choose 3) options for the places of the separators. This is the total number of ways to write 32 as sum of four positive integers. Afterwards the ways with x4>25 are subtracted.
Likes Charles Link
OP, your post doesn't make sense. First it is 32, then it is 28. Which is it? Also I get a different answer: 4460 (no, it is 4475, I thought x4 < 25). You'll need to be much more clear before I give any further information about my method.
The OP apparently is doing the case of 28, but I think he is also doing ## x_4<25 ##. If it is ## x_4 \leq 25 ##, the second term should be ## \frac{5!}{2! \, 3!} ## because the term that would be subtracted is the number of ways that ## x_1+x_2+x_3 ## can be 2 or less.
Let's check the excluded cases individually:
x4=26 gives x1+x2+x3=6 which has just the options 1+1+4, 1+2+3, 2+2+2 and permutations of it (total: 3+6+1=10).
x4=27 gives x1+x2+x3=5 which has just the options 1+1+3, 1+2+2 and permutations of it (total: 3+3=6).
x4=28 gives x1+x2+x3=4 which has just the option 1+1+2 and permutations of it (total: 3).
x4=29 gives x1+x2+x3=3 which has just the option 1+1+1 (total: 1).
-> we have to subtract 20. Or (6 choose 3) as can be derived in the same way as the (31 choose 3). This time we are interested in the number of ways x1+x2+x3 ≤ 6, or x1+x2+x3+y ≤ 7 with a positive y to get the same situation as before. The answer in post 1 is correct.
Likes Charles Link
My mistake. I was working it with ## x1,x2,x3,x4 \geq 0 ##, (instead of ## >0 ##). ## \\ ## Additional comment: In his solution in the original post, I think the OP changed what ## x1,x2, ## and ## x3 ## represent. He is letting them be additional amounts that get added to the group which are already assumed to have one unit in them. The OP has a very good solution, but I don't think he presented his solution as clearly as he could have.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
