aditya ver.2.0
- 67
- 4
My question is the same as the title 'Is there a boundary present for our universe?'
The discussion centers on the existence of a boundary in the universe, highlighting the distinction between bounded and unbounded models. Participants clarify that a bounded universe implies finite space, while an unbounded universe can still have a boundary, akin to the surface of a balloon. The observable universe is confirmed to be temporally bounded, with a finite age of approximately 13.8 billion years, but its spatial extent remains uncertain. The conversation emphasizes that while the observable universe has limits, the overall universe may be infinite and lacks definitive boundaries.
PREREQUISITESAstronomers, cosmologists, and physics enthusiasts interested in the fundamental nature of the universe and its boundaries will benefit from this discussion.
Are there actually any models that use a boundary? (and to be clear, I don't mean being bounded)Shyan said:But whether there is actually some boundary to the universe, we still don't know. Different cosmological models make different assumptions and so we can just work with different answers and see what will come out!
Actually I was using "model with a boundary" interchangeably with "a model suggesting a bounded universe".Bandersnatch said:Are there actually any models that use a boundary? (and to be clear, I don't mean being bounded)
Wouldn't that contradict the notion of universality? Set containing all elements? What would a point outside of the universe even be? Multiverse stuff?Bandersnatch said:Having boundary means that you can name points that lie outside the set - i.e., in 3D space you go one way until you reach the "end" of the universe, beyond which there is something else.
Shyan said:Actually I was using "model with a boundary" interchangeably with "a model suggesting a bounded universe".
I'm not that much into cosmology and can't name different models but I know there are models saying universe is infinite and others saying its finite. So I was referring to this. I thought having a boundary is the same as being bounded. I mean, its the definition of boundary to bound something, right?(or wrong?)
You're mixing the dimensions.elusiveshame said:Correct me if I'm wrong, but couldn't you have an unbounded universe that has a boundary, similar to a balloon (has boundary, but if you go straight, you'll just end back up at the starting point)?
I'm not sure of the various models, but I thought I've seen that mentioned somewhere on PF.
Bandersnatch said:You're mixing the dimensions.
A balloon's surface (a 2D space) is without a boundary and bounded. It's volume (3D) has a boundary and is bounded. Infinite 3D space minus the volume of the balloon is unbounded and has got a boundary.
When used as an analogy to visualise the expansion of the universe, only the 2D surface of a balloon is being considered.
Bandersnatch said:Apologies, I can't quite follow your question. I think there's still some confusion, and not unexpectedly so, considering the nomenclature.
Bounded means basically the same as "finite". Unbounded is then infinite. As in, we don't know whether the universe is bounded or not = we don't know if it's finite or infinite.
Boundary means the same as "edge". E.g., the observable universe is bounded = it's got an edge (beyond which we can't see), but the Universe as a whole doesn't.
Perhaps we should stick to "in/finite" and "edge" as they are less prone to getting confused with each other.
Could you try and reword your question using those terms?
(mind you, this is all talking about space, not space-time)
That is, it has a start and an end? I was of the impression time got way complicated in early-universe stuff so that the question of "before that" becomes too difficult or even pointless.Chronos said:All evidence suggests the observable universe is temporally bounded
