Is There a Contradiction in Weinberg's QFT Book on Simultaneous Eigenstates?
  • Context: Graduate
  • Thread starter Thread starter diraq
    Book Qft
The discussion revolves around a potential contradiction in Weinberg's Quantum Theory of Fields regarding the simultaneous diagonalization of operators A, B, and the energy-momentum operator Pμ. Participants examine the implications of commutation relations and eigenstates in the context of quantum field theory.
  • One participant questions the assertion that operators A and B can be simultaneously diagonalized with the eigenstate \Psik,a,b, given that [A,Pμ]\neq 0 and [B,Pμ]\neq 0.
  • Another participant argues that while A and B do not generally commute with Pμ, they leave the state k=(0,0,1,1) invariant, suggesting that they can be simultaneously diagonalized on this state.
  • A different participant challenges the previous claims by stating that the derived commutation relations indicate non-zero results, implying a contradiction in the simultaneous diagonalization.
  • Some participants propose that there may be a sign error in the calculations, suggesting that a different momentum representation could resolve the issue.
  • One participant references external notes to suggest considering A2 + B2 instead of A and B individually, although they have not verified the commutation relations.
  • Another participant insists that there is no sign error and provides a detailed calculation of the commutation relations involving A and P1, while also inviting others to share their derivations.
  • Further discussion includes a claim that a sign error exists in a specific formula from Weinberg's text, pointing to discrepancies between different equations.
Participants express differing views on the validity of the simultaneous diagonalization of A, B, and Pμ. There is no consensus on whether a sign error exists or how to resolve the apparent contradictions in the commutation relations.
Participants reference specific equations from Weinberg's text and external notes, indicating that the discussion is highly technical and dependent on precise mathematical formulations. The validity of certain assumptions and the correctness of derived relations remain unresolved.
diraq
I am reading Weinberg's Quantum theory of fields Vol I and have a question about the derivation on page 71.
Right below eq. (2.5.37), it is written that [tex]A[/tex] and [tex]B[/tex] can be simultaneously diagonalized by [tex]\Psi_{k,a,b}[/tex]. From the content, I inferred that [tex]\Psi_{k,a,b}[/tex] is also the eigenstate of the energy-momentum operator [tex]P^\mu[/tex] with eigenvalue [tex]k=(0,0,1,1)[/tex]. But, since [tex][A,P^\mu]\neq 0[/tex] and [tex][B,P^\mu]\neq 0[/tex], there should not be such simultaneous eigenstate for [tex]A,B,P^\mu[/tex].
Please help me on this. Thanks in advance.
[tex]A[/tex] and [tex]B[/tex] leave [tex]k=(0,0,1,1)[/tex] invariant, so while they don't generally commute with the momentum operator, it's true that
[tex] [A,P^\mu] \Psi_{k,a,b}= [B,P^\mu] \Psi_{k,a,b}= 0.[/tex]
So [tex]A, B, P^\mu[/tex] are simultaneously diagonalizable on this state.
Thank you very much. The problem is [tex][A,P^1]=-iP^3-iH=[B,P^2]=-iP^3-iH[/tex], so [tex][A,P^1]\Psi_{k,a,b}=-2i\Psi_{k,a,b}=[B,P^2]\Psi_{k,a,b}\neq 0[/tex].
There must be a sign mistake somewhere. For example, if P=(0,0,-1,1), and everything else was unchanged, then it would work as fzero says.
I checked and there is no such sign mistake. I read from the following notes:
http://www.physics.buffalo.edu/professors/fuda/Chapter_3.pdf
Probably it is better to consider [tex]A^2+B^2[/tex] rather than [tex]A[/tex] and [tex]B[/tex] individually. But I haven't checked the commutation relations.
Yes, you DID make a sign error. Verify it again (i just computed one relation and it worked out fine)!
Well, let's do [tex][A,P_1][/tex].
[tex][A,P_1]=[J_2,P_1]+[K_1,P_1][/tex]. Using eq. (2.4.21) and (2.4.22), we have [tex][J_2,P_1]=i\epsilon_{213}P_3[/tex] and [tex][K_1,P_1]=-iH[/tex]. Since [tex]\epsilon_{213}=-1[/tex], I got the result [tex][A,P_1]=-i(P_3+H)=-i(P^3+P^0)[/tex].
If possible, please post your derivation. Thanks.
The mistake is in your first line, A = J_2 - K_1. If you would have cared, you would notice that Steven made a sign error in formula 2.5.33 if you compare with 2.4.17.
Thanks!
