Is There a Mistake in This Boolean Algebra Simplification?
6 replies · 5K views · last reply
bd411
Simplify the following boolean expression:
A'C + A'C'D + ABC + ABC'D
I have a solution but when I checked against a boolean algebra simplifier online it gave me a different answer... is there a glaring mistake below ?
None.
= A'(C + C'D) + AB(C + C'D)
= A'(C + D) + AB(C + D) = A'C + A'D + ABC + ABD
= C(A' + AB) + D(A' + AB)
= C(A'B + 1) + D(A'B + 1)
= C(1) + D(1) = C + D.
Any help would be much appreciated !
This isn't correct. Consider that if [itex]A[/itex] is true and [itex]B[/itex] is false, then [itex]A' + AB[/itex] is false, while [itex]A'B + 1[/itex] is always true.
None.
= C(A'B + 1) + D(A'B + 1) ??
You did so well with (C + C'D) = (C + D) at the start; use the same deal here.
Hmm right so I could say that (A' + AB) = (A' + B)
In which case C(A' + B) + D(A'+B) = A'C + BC + A'D + BD.
I'm a little stumped as to how this simplifies further.
Sorry the answer should be BC + BD + A'C'D !
I'm a little stumped as to how this simplifies further. The answer in front of me says it should be BC + BD + A'B'. I have two of those terms, but I'm having a little trouble extracting A'B' out of A'C + A'D !
I think the answer you have in front of you is wrong. I get the same thing as you, which can be rewritten as (A'+B)(C+D). Wolfram Alpha also agrees.
You're welcome!:smile:
P.S. To see why BC + BD + A'C'D is incorrect, consider the case where A is false and C is true. To see why BC + BD + A'B' is incorrect, consider the case where both A and C are false.
