Is there a relationship between the harmonic mean and the standard deviation?
5 replies · 2K views
Feynstein100
I was doing a thought experiment on the harmonic mean. Let's say we have a sequence of 4 numbers:
100, 110, 90, 100
The arithmetic mean (AM) of this sequence is 100 but the harmonic mean (HM) is 99.4975.
Let's imagine that the initial and final values remain constant but the middle ones get more and more extreme.
100, 120, 80, 100
The AM is still 100 but the HM is now 97.9592
100, 130, 70, 100
AM = 100, HM = 95.2880
and so on
I think I understand why this happens. The AM is symmetric, if you will. So an equal movement above the mean will cancel out an equal movement below it. However, the HM is more skewed toward the lowest value in the sequence. As such, it only takes one low value to bring the HM down. And with each step, we have a lower minimum and thus a lower HM. This is basically a crude verbal proof. Is there a more rigorous, mathematical one?
I'm also interested to know if there's a relationship between the HM and the fluctuation (I guess the arithmetic standard deviation is a good way to represent this). I mean, there has to be, as higher fluctuations mean higher likelihood of lower values and thus a lower HM, right?
Basically, HM = f(σ)?
Imagine a variable x with a distribution N(μ,σ2), i.e. a Normal distribution with mean μ and variance σ2. Think of x as μ + δ where δ = N(0,σ2), and (for simplicity) σ << μ. Can you derive an (approximate) expression for HM, where HM = 1/E(1/x)?
Sounds interesting. But what exactly is E in this case? 😅
mjc123 said:
The expectation (mean of the distribution).
Ah okay but isn't that literally the definition of the harmonic mean? Not sure what we'd get by proving it. I mean, I'm trying to find a relationship between HM and σ, not HM and E.
Also, in the example, the E remained constant whereas the HM kept decreasing, exactly illustrating my point. Although, oh wait. That was the AM, not E(1/x). My bad 😅
