Is there a strictly algebraic way of coding "whole number value of"?
  • Context: Graduate
  • Thread starter Thread starter David Carroll
    Coding Value
The discussion centers on the question of whether there is a strictly algebraic method to represent the concept of "whole number value of" for irrational numbers. Participants explore the possibility of manipulating algebraic symbols to separate the whole part from the decimal expansion of a number derived from polynomial equations.
  • One participant inquires if there is a way to algebraically separate the whole part of an irrational number from its decimal expansion, specifically using symbols from the polynomial equation.
  • Another participant proposes a Boolean function, ##\Phi_0(z)##, which can determine if a number is within a certain range and suggests that this function can be used recursively to find the integer part of a number.
  • Concerns are raised about the efficiency of the proposed recursive algorithm compared to known algorithms like Shor's algorithm.
  • A participant argues that the recursive algorithm essentially checks for integer values iteratively, suggesting that it may not be as efficient as directly computing the square root of a number.
  • One participant concludes that it is not possible to have an algebraic closed formula for obtaining the whole number part of most numbers, as algebraic numbers constitute only a small subset of real numbers.
Participants express differing views on the feasibility and efficiency of the proposed methods for obtaining the whole number part of irrational numbers. There is no consensus on whether a strictly algebraic method exists.
The discussion includes corrections to earlier statements regarding the quadratic formula and the nature of the proposed algorithms. Limitations regarding the definitions of algebraic versus irrational numbers are acknowledged but not resolved.
David Carroll
Greetings in the name of Jah-gonaut, ladies and gents. I have a question. Is there a strictly algebraic way of coding the notion "whole number value of", specifically for an irrational number?
I know that one way of coding the notion "absolute value of" some number is taking the square root of the square. Can something similar be done to code for "whole part" of some number, using only algebraic symbols or numbers? Namely, in my case, can some kind of manipulation of symbols be done with the irrational part of a solution to some polynomial equation {by which I mean the "sqrt(b2 + 4ab)" part of the solution)}, using ONLY the symbols a or b?
For example, let's take the two solutions to the polynomial equation x2 + 21x - 155 = 0:
-26.7864974749... and 5.7864974749...
I want to separate the decimal expansion from the whole value 5 for the second solution. But I want to perform this step using only algebraic symbols, pretending - say - that I'm some machine that doesn't otherwise know the command "separate the whole part from the decimal expansion".
Can I perform some finite manipulation of the symbols a, b, or c (from the polynomial formula) to do this?
Mathematics news on Phys.org
Correction: "sqrt(b2 + 4ab)" should read "sqrt(b2 + 4ac)"
Actually, correction again: that is "- 4ac", not "+ 4ab". And that is, quadratic formula, not polynomial formula.
Assume we're only dealing with real numbers.
Let ##\Phi_0(z)\equiv##"##\exists a,b\in\mathbb R \text{ such that } z = a^2, \enspace 1-z = b^2 \text{ and } b\neq 0##." It's straightforward to check that ##\Phi_0(z)## is true if and only if ##z\in[0,1)##.
For any ##n\in \mathbb N##, let ##\Phi_n(z)\equiv \Phi_{n-1}(z-1)## and ##\Phi_{-n}(z)\equiv \Phi_{-(n-1)}(z+1)##.
It's straightforward to check that ##\Phi_n(z)## is true if and only if ##\lfloor z\rfloor=n##.
I would argue that the Boolean ##\Phi_0## is just as algebraic as ##\sqrt{\enspace}## is. Given that, you could get a computer to (recursively) check ##\Phi_n, \Phi_{-n}## for each ##n##, and it will eventually terminate and find your integer part.
How efficient is such an algorithm on a computer? Quicker than, say, shor's algorithm?
I guess, since it's recursive, it would be just as efficient as taking the square root of a real number?
Every recursive algorithm can be transformed to an iterative algorithm. The recursive algorithm that has been proposed amounts to iteratively checking whether ##i^2 > x >= 0## for each non-negative integer i in order until one is found that satisfies the test. The floor of the square root of x is given by the first i that passes the test.
That algorithm takes approximately 10^5 steps to determine the floor of the square root of 10^10 - 1.
It is possible to compute the square root of 10^10 - 1 to 5 significant digits in WAY fewer steps than that.
Suppose you can apply ##+,-\times,\div##, and roots to some irrational ##\alpha## (and algebraic numbers) to get a whole number ##n##. Then you get ##R(x)-n## is an algebraic function with ##\alpha## as a zero (where ##R(x)## was the closed formula used). Consequently, ##\alpha## is algebraic.
So it is not possible to have an algebraic closed formula (as opposed to recursive algorithm) that gives the whole number part of most numbers (since the algebraic numbers are barely any of the real numbers).
This is disappointing news. But thank you.
  • · Replies 22 ·
  • · Replies 23 ·
