Is there any way to prove that a given force is conservative?
  • Context: Undergrad
  • Thread starter Thread starter alphabeta1720
    Force
The discussion revolves around the criteria for determining whether a given force is conservative. Participants explore mathematical definitions, examples, and specific cases related to conservative forces, including the use of curl and potential functions.
  • Homework-related
  • Some participants propose that a force is conservative if the curl is zero, or if the net work done is zero when moving a particle along a closed path.
  • Others argue that a vector field is conservative if it can be expressed as the gradient of a potential function, implying that the work done depends only on the difference in potential between two points.
  • A participant suggests analyzing simple systems, like a pendulum or an object on a frictionless surface, to understand conservative forces better.
  • One participant raises specific questions about determining whether a two-dimensional force is conservative without additional information, and discusses the conditions under which a potential function exists.
  • Another participant mentions the "cross condition" involving mixed partial derivatives as a criterion for conservativeness.
  • Several forces are presented for analysis, with participants encouraged to apply the discussed criteria to determine which are conservative.
There is no consensus on a single method for proving that a force is conservative, as participants present multiple approaches and criteria. The discussion includes both mathematical and conceptual perspectives, indicating a range of views on the topic.
Some participants express uncertainty about mathematical concepts such as curl and the del operator, which may limit their ability to engage fully with the discussion. The discussion also includes specific examples and conditions that may not be universally applicable.
This discussion may be useful for students and individuals interested in classical mechanics, vector calculus, and the properties of forces in physics.
alphabeta1720
Yes, a force is conservative if the curl is zero.
Or, equivalently, the net work done is zero if you move a particle in a path that starts and ends in the same place.
Mathematically a vector is said to be conservative if it is the gradient of a potential
This means that for the space considered there must be a potential at every point ( can be zero ) and the work done from moving from one point to another depends only on the difference between the potentials at these two points. So the path has no say
If you want to know if a force is conservative, and if you have the equation for the force ( in terms of catesian or polar co ordinates ) then you have use the mathematical curl operation (del cross f) where del is the vector derivative with respect to space. If the force f is conservative this term will be zero.
The reason for that is that a gradient can be represented as (del V ) where V is a scalar potential.
Then the curl operation becomes ( del cross del V ) since these 2 vectors point in the same direction the cross product has to be zero.
more on del operator
http://hyperphysics.phy-astr.gsu.edu/hbase/vecal.html
i'm not sure from your question, but you can prove this by analyzing a few simple/isolated systems such as an object hung to a string on a frictionless surface, a simple pendulum, and many others examples, those are simple, and you can further study about the conservation of energy for more understanding.
Thank you for that
but can anyone help me solving these problems (Sorry, but I don't know about 'curl' and 'del' operators)
Q1 Consider the two dimensional force F = f(x,y) i + g(x,y) j . Is it possible to determine whether this is a conservative force without any additional information? What if f(x,y) = f(x)
and g(x,y) = g(y)
Q2 which of the following forces is conservative?
A) F = y i - x j B) F = xy i - xy j
C) F = y i + x j D) F = xy i + xy j
E) F = 3x i + 4y j
(There may be more than 2 correct answers)
Thank You
alphabeta1720 said:
Thank you for that
and g(x,y) = g(y)
Yes, there is. The work done in moving an object using that force along a path in the plane by [itex]\int_p \vec{F}\cdot d\vec{s}= \int_p f(x,y)dx+ g(x,y) dy[/itex] depends only on the beging and ending points and is independent of the specific path. Once can show that that is true if and only if there exist some "potential function" G(x,y) (numerical valued, not vector valued) such that [itex]\nabla G= \vec{F}[/itex] which just means that
[tex]f(x,y)= \frac{\partial G}{\partial x}[/tex]
and
[tex]g(x,y)= \frac{\partial G}{\partial y}[/tex]
Assuming there is such a function G, then
[tex]\frac{\partial^2 G}{\partial y\partial x}= \frac{\partial f(x,y)}{\partial y}[/tex]
and
[tex]\frac{\partial^2 G}{\partial x\partial y}= \frac{\partial g(x,y)}{\partial x}[/tex]
Since, as long as the derivatives are continuous, the "mixed derivatives" are continuous, we can say that a force, [itex]\vec{F}= f(x,y)\vec{i}+ g(x,y)\vec{j}[/itex] is "conservative" if and only if it satifies the "cross condition"
[tex]\frac{\partial f}{\partial y}= \frac{\partial g}{\partial x}[/tex]
E) F = 3x i + 4y j
Thank You
Apply the condition
to each of those.
(I can't help but think that if you are asked a question like this, you are expected to have learned all this before!)
OK! next I am going to do is to learn about them
  • · Replies 24 ·
