- 978
I just watched Sabine's Hossenfelder very recent new video on the Quantum Cheshire effect.
From experience, everything Sabine's says on either entanglement/quantum interpretations or not-physics, is heavily biased to her worldview. However I thought it was fun to see what she was going to say about this topic.
She claims that this recent paper : https://iopscience.iop.org/article/10.1088/1367-2630/ad0bd4 finds that the usual interpretation of the quantum Cheshire cat is flawed.
The paper provides a version of the effect using a modified Mach-Zehnder interferometer with a single detector:
A diagonally polarized light beam (D) is sent from the yellow dot (bottom left), passes by beam splitter BS1 and takes path 1 and path 2. In path 2, there is a half wave polarizer (HWP) rotating the state to an antidiagonally polarized state (A). As the two paths are different they do not recombine when arriving to the second beam splitter BS2. The photons that go to the right, pass by a polarising beamsplitter (PBS), which transmits beams with the original polarization (D) and sends it to the detector (red checkmark in the upper right). If the polarization was rotated
(A), it reflects it away from the detector.
It seems obvious that the photons that took path 1 are able to be detected. Photons that took path 2 seem not to contribute. The Cheshire effect here seems to appear when you slightly modify change the rotation of the HWP by a tiny amount (weak measurement). Under these tiny modifications, it seems that the number of photons detected is modified, implying some kind of quantum Cheshire effect! (modifications of the lower arm should not participate, yet it modifies it, polarization takes a separate path?!).
The result seems trivial, what I cannot understand is what is Cheshire like from it. Clearly modifying anything in the lower arm is going to rotate states in another basis providing more possible photons that can be detected coming from path 2. Sabine makes a similar remark, saying with authority that the interpretation where the cat"disembodied" it finally proven wrong!
The paper seems more conservative, it provides three not equivalent interpretations. I am having a hard time understanding the three different assumptions because they focus too much of contextuality and weak measurement remarks.
What do you think of it? Is this a valid quantum Cheshire cat? It seems too obvious to me, and I hope that I am misunderstanding something (as well as Sabine). It seems very obviously not a quantum effect, where is the catch?
