Is this another "paradox" or a veritasium mistake?
  • Context: Undergrad
  • Thread starter Thread starter mgkii
The discussion revolves around a claim made in a Veritasium video regarding the behavior of light in an accelerating spaceship compared to an inertial reference frame. Participants explore the implications of light's path as observed from different frames of reference, questioning whether the video accurately represents these phenomena. The scope includes conceptual understanding of relativity and light behavior in both classical and relativistic contexts.
  • Some participants express confusion about the claim that an outside observer would see no bend in the light path, questioning how this aligns with their understanding of light behavior in accelerating frames.
  • One participant notes that in an inertial frame, light travels in a straight line, while in an accelerating frame, the path appears curved due to the motion of the spaceship.
  • Another participant argues that while the inertial observer sees the same emission and impact points, the impact point would have moved relative to the emission point after the light ray was emitted.
  • Some participants suggest that the video may have oversimplified the explanation, leading to misunderstandings about the observations from different frames.
  • There is mention of classical physics principles where light can bend in an accelerating reference frame, similar to the relativistic case.
  • Concerns are raised about the video’s assertion regarding charges under constant proper acceleration and their radiation, with some participants questioning the accuracy of this claim.
  • A later reply emphasizes that the deflection predicted by general relativity matches that of classical acceleration in the local context of the accelerating spaceship.
Participants do not reach a consensus on whether the video contains a mistake. Some argue that the video is incorrect in its depiction of light behavior, while others defend its claims about light traveling in straight lines in inertial frames. The discussion remains unresolved with multiple competing views.
Participants highlight limitations in the video’s explanation and the potential for misunderstanding due to its presentation. There is also a distinction made between local effects in the accelerating spaceship and broader implications in general relativity.
mgkii
TL;DR
Laser pointer shot across a spaceship in deep space hits the wall directly across from it. When the spaceship accelerates the beam curves and hits lower down. However, an outside observer will (according to the video source) observe no change in light path.
This Veritasium video https : / / youtu.be / XRr1kaXKBsU?si=zNqHwmCTq-cmcsbW (spaces added in case there's an issue with posting URLs) at 13:04 makes a statement which I can't get my head around. Veritasium videos always seem to be well researched so my working assumption is it's my lack of brain power rather than their mistake! However, I can't see a direct reference to this one on the forum.
The video describes a spaceship in deep space under no acceleration. A laser pointer it set up to point across the ship (side to side as opposed to nose to engine) and as expected, the pointer highlights a spot directly across from the source. The spaceship then fires up an goes into constant acceleration and the laser point moves down the wall slightly in the same way it would if the acceleration were due to gravity. So far so good.
The video then goes on to say that an outside observer in an inertial FOR would see no bend in the light path. My understanding breaks here, because they couldn't see the light hitting a different part of the wall, so how would they see something different? I would have reasoned that an outside observer would see exactly the same effect as the accelerating observer; the movement of the light beam is perpendicular to the direction of acceleration.
Am I missing something or was it an error in (as far as I can tell) an otherwise excellent video?
Many thanks in advance
Matt
In the inertial frame the light goes straight. The accelerating rocket’s path is a parabola in spacetime. So they see the laser hit lower because the rocket’s path has curved up.
The inertial observer would see the same emission and impact points, but that impact point would have moved (relative to the point of emission) after the light ray was emitted.
A straight line in an inertial reference frame may be curved in an accelerating reference frame and vice versa.
PS note that this scenario in itself is not peculiar to special relativity. In classical physics, a light beam could bend in an accelerating reference frame and be a straight line in an IRF. As could the motion of any particle.
So it is a mistake in the video. Many Thanks Indeed everyone! Happy to close the thread if that's the normal protocol.
I didn't watch the video, but I assume it's correct. Light moves in a straight line in an IRF.
mgkii said:
TL;DR: Laser pointer shot across a spaceship in deep space hits the wall directly across from it. When the spaceship accelerates the beam curves and hits lower down. However, an outside observer will (according to the video source) observe no change in light path.
The video is somewhat lax in the explanation.
Good catch!
We can take as true for the spacecraft thought experiment in that light travels in a straight line for a non-accelerating observer.
With the coasting rocket ( no acceleration ) the light beam hits the wall a a particular point on the opposite wall - ie the 0 ( zero ) mark as seen in the video. Same observation for the outside inertial astronaut.
With the accelerating rocket the light beam hits a spot lower down, say spot B.
Both observers should see that.
Astronaut in the accelerating ship concludes that light has curved.
Inertial astronaut outside the ship concludes the the ship has moved up ( ie ship has different velocity at time of absorption ( at B ) from the velocity at previous time of emission.
His Veritasium statement that the inertial astronaut sees the same thing - ie light is moving in a straight line - but offered little else on what the inertial astronaut sees on the opposite wall ( spot B )
I watched the relevant part of the video. The video is correct, in what it says about light as measured in inertial and accelerating reference frames. Note that, as above, that is as expected.
The difference in this context between classical physics and relativity is that the light would bend twice as much when calculated using the equations of GR as it would using the classical acceleration of gravity.
Shoot. I was writing and did not see all the other responses coming in. :wideeyed:
This is true for the total global deflection over a large region around a mass, where the effects of spatial curvature become non-negligible. For the local experiment in the accelerating space-ship, where the effects of spatial curvature are negligible, the deflection predicted by GR matches the one by classical acceleration of gravity.
See:
https://www.mathpages.com/rr/s8-09/8-09.htm
I'm not so sure about the end of the video though, where it claims that charges under constant proper acceleration (e.g. resting on the Earth's surface) would be "radiating" according to relativity, but we could not test this so far.
I rather think that charges under constant proper acceleration have a distorted but static E-field in their rest frame, according to relativity. You need a changing proper acceleration of a charge to radiate energy away, in a frame invariant manner.
I just watched a bit of it. I must admit, I'm not predisposed to watch a video where someone claims everyone else is wrong!
It's quite ironic that Veritasium found corroboration here. That might even be considered a paradox.
See:
I've just been out for a bike ride and I was wondering about that as I was cycling round!
Yes, they would, but this would be attributed to the spaceship accelerating rather than the light following a curved path.
Yes, I would say the video is wrong in that spot. The two mistakes in that clip are:
(13:18) From the perspective of the external inertial observer when he correctly says that the light travels in a straight line they show a graphic of it hitting the original location on the wall (it will actually hit lower because the light goes straight and the rocket accelerates)
(13:29) In the rocket’s accelerating frame the rocket is always at rest. So in the accelerating frame it is not true that the rocket has sped up. So that cannot be the reason in that frame that the light’s path curves.
Good catch. You are correct. What the man says from 13:04 to 13:20 seems all correct, but the video illustration is bad. Everyone sees the light hit the same spot on the spaceship wall. Relative to the ship's accelerating frame, the light path curved down and hit the wall lower. Relative to the non-accelerating observer's reference frame, the light goes straight and the ship wall accelerates up, so the light hits the wall lower. They both see the light hit the same spot on the ship wall. The video illustration does not show that correctly, but all the statements are correct.
I missed that. I assumed he was still talking about inertial rocket motion at that point.
This is the problem with spending all the effort dressing up in a rocket suit. Instead of showing us the two perspectives of the two cases drawn on a blackboard!
As @A.T. pointed out, this is not correct. The factor of 2 you describe here is global, not local; the local light bending in relativity, which is what is being described in the video, is the same as it would be in Newtonian physics. The global factor of 2 comes from the contribution of spacetime curvature to the global path of the light; in the local context spacetime curvature is not detectable.
I already read and replied to his response.
And making the animations appealing rather than accurate. The rocket doesn’t appear to be accelerating, or at least if it is accelerating it is too subtle to be visible.
I'm not sure if this is the case here, but I think it's common to have the graphics done by someone else. And at some point, one might simply give up explaining how it is still not quite accurate. Just like when you contribute a chapter to a technical book, and the publisher has the diagrams redone by their graphics department, which is clueless about what they mean.
I never had a disconnect between audio and visuals when watching 3blue1brown videos, because he makes everything himself.
IMO, Veritasium tries hard to be correct. It might be nice to leave a comment on the video about the mistake.
UPDATE: I see that the video already has an appropriate comment by Rafael Silva.
PS. Proofreading your own work is a hard, endless, thankless, job.
The video was posted 5 years ago and has already been described in the comments as a "masterpiece"!
That said, it would be interesting to see the reaction to a proposed correction at this stage.
It would be bent twice as much by a mass. But I don't think not on an elevator. I don't have a reference for this statement, but I believe it to be true. If you want to be absolutely sure, you'll need to either do your own calculation of the path of light in a Rindler frame, look up such a calculation (and hope it's right), or find some other reference.
To be more precise: the global bending of light when passing close by a massive object, i.e., the angle between its incoming path at infinity, and its outgoing path at infinity, is twice what you would expect from a naive Newtonian calculation
To be more precise: the local path of light through an accelerating elevator is "bent" downwards by the same amount as you would expect from a naive Newtonian calculation.
Yes, I was in a bit of a rush - though I probably couldn't be that precise anymore anyways. (Was I ever? Probably not, not that it matters). But that's the essence of why I think the factor of 2 is not present in this case. Basically, a purely Newtonian calculation should be good enough to handle the problem and there's no factor of 2 in said calculation. One simply take the travel time of the light, and during that travel time use the Newtonian formula for how far the rocket moves in that time period - i.e. 1/2 a t^2, as long as the rocket isn't accelerating for too long. "Too long" would be a good fraction of a year at 1g. So - no more than a few days to keep below 1 percent of c.
There shouldn't be any issues with the relativity of simultaneity or other relativistic effects that I can think of in this Newtonian analysis. The time coordinate that's held constant for the path of light in the instantaneous inertial frame should also be a constant Rindler time coordinate T. (If I was going to make an error, not unh eard of, this is probably where it would be).
I am pretty sure that my take on the "extra" deflection of light would generate some arguments, which I probably won't respond to - but I'm inclined to give the argument anyway for whatever it's worth, even if I may not h ave the time to get into a long conversation about it.
I use a coordinate dependent analysis - the coordinates I use are the PPN coordinates. And in those coordinates, I attribute the "extra" deflection to the PPN parameter gamma. Which is described as being a measure of spatial curvature in those specific coordinates. (The concept of what part of space-time curvature is "spatial" is of course coordinate dependent, which is why I am specifying what coordinates I am using in my argument).
If one consults wiki - which I believe takes the same information from MTW) - the PPN paramter for the extra curvature of light, gamma is described as
wiki said:
\gamma How much space curvature ##g_{ij}## is produced by unit rest mass.
And the curvature of light is entirely determined by ##1+\gamma## in the PPN formalism. Because ##\gamma## is one in General relativity, we see that light deflects twice as much.
That's my argument for why I attribute the "extra" curvature of light around a massive object to "spatial curvature", where the decomposition of the space-time curvature into a spatial part is given by the specific conventions used to define the PPN coordinates.
This spatial curvature is simply lacking in the case of light on an accelerating rocket / Einstein elevator / Rindler coordinates. (Rindler coordinates are spatially flat). Thus, I would not expect an extra factor of 2 for the deflection of light.
  • Skeptical
Yes, that's correct for those coordinates. A more general statement would be that the factor of 2 in the global deflection is due to spacetime curvature; in those particular coordinates, the relevant spacetime curvature appears in the "spatial curvature" of surfaces of constant coordinate time.
Or, in more general terms, spacetime is flat in this case. And the same is true locally even in curved spacetime; the curvature does not affect a local analysis like the "rocket" analysis.
The irony is that this thought experiment about light being deflected in a gravitational field doesn't lead to anything verifiable. In the notes that @A.T. posted, it's claimed that Newton had in fact calculated the gravitational deflection of light as it passes Earth. So, all we have is two numerically equivalent predictions.
I think that's very funny. It had never occurred to me before that the local calculations yield the same answer.
In theses notes is also mentioned, that Johann Georg von Soldner calculated the gravitational deflection of light as it passes the sun. He did this in 1801 (published in 1804), based on Newton's theory:
https://en.wikisource.org/wiki/Tran...on_of_a_Light_Ray_from_its_Rectilinear_Motion
  • · Replies 47 ·
  • · Replies 24 ·
  • · Replies 98 ·
9K
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 25 ·
  • · Replies 45 ·
  • · Replies 19 ·
