Is this conditional probability has derived correctly?
8 replies · 2K views
sabbagh80
Hi friends,
The problem:
Assume the events [itex]A_i[/itex] for [itex]i=1,2,...,n[/itex] are of the same type. please trace the following relations.
[itex]P(X│A_1 A_2…A_n )= \frac{P(X)}{P(A_1 A_2…A_n )} P(A_1 A_2…A_n│X)=[/itex]
[itex]\frac{P(X)}{P(A_1 A_2…A_n )}[ (-1)^{n-1} P(⋃_{i=1}^{n} A_i │X)+(-1)^{n-2} {n \choose 1} P(A_1│X)+[/itex]
[itex](-1)^{n-3} {n \choose 2}P(A_1 A_2│X)+…+{n \choose n-1}P(A_1 A_2…A_{n-1}│X) ][/itex]
[itex]= \frac{1}{P(A_1 A_2…A_n )} [ (-1)^{n-1} P(X|⋃_{i=1}^{n}A_i ) P(⋃_{i=1}^{n}A_i)+ (-1)^{n-2} {n \choose 1}P(X│A_1 )P(A_1 )+(-1)^{n-3} {n \choose 2} P(X│A_1 A_2 )P(A_1 A_2 )+[/itex]
[itex]…+{n \choose n-1}P(X│A_1 A_2…A_{n-1} )P(A_1 A_2…A_{n-1}) ][/itex]
[itex]=(-1)^{n-1} \frac{P(⋃_{i=1}^{n}A_i )}{P(A_1 A_2…A_n )} P(X|⋃_{i=1}^{n}A_i )<br /> +(-1)^{n-2} \frac{P(A_1 )}{P(A_1 A_2…A_n )} {n \choose 1} P(X│A_1 )+(-1)^{n-3} \frac{P(A_1 A_2 )}{P(A_1 A_2…A_n )} {n \choose 2} P(X│A_1 A_2 )+[/itex] [itex]…+{n \choose n-1} \frac{P(A_1 A_2…A_{n-1})}{(P(A_1 A_2…A_n)} P(X│A_1 A_2…A_{n-1} )[/itex]
Is everything OK? thanks a lot in advance for your involvement!
sabbagh80,
That doesn't make sense. It's probably because you intend notation like [itex]{n \choose 2}P(A_1 A_2│X)[/itex] to mean [tex]\sum_{\{(i,j):1 \leq i \le n, 1 \leq j \leq n, i \neq j\}} p(A_i A_j|X)[/tex].
And I don't understand why the term [itex]P(\cup_{i=1}^n A_i|X)[/itex] would need a factor of [itex](-1)^{n-1}[/itex] with it.
Stephen Tashi,
By [itex]{n \choose 2}P(A_1 A_2│X)[/itex], I don't mean:
[itex]\sum_{\{(i,j):1 \leq i \le n, 1 \leq j \leq n, i \neq j\}} p(A_i|X)p(A_j|X)[/itex]
I mean [itex]\sum_{\{(i,j):1 \leq i \le n, 1 \leq j \leq n, i \neq j\}} p(A_iA_j|X)[/itex]
I just used the inclusion exclusion property of probability.
I want to write [itex]P(A_1 A_2…A_n│X)[/itex] according to the above property.
I was editing my message as you replied. See my revised version.
The point is that the use of the specific indices 1 and 2 in your expression does not convey the fact that you want the indices to vary over all possible pairs of distinct indices. (You do want that, right? Otherwise the [itex]n \choose 2[/itex] doesn't make sense.)
That is the correct idea. Just get the notation fixed.
As I mentioned in my problem, I have:
[itex]\sum_{\{(i,j):1 \leq i \le n, 1 \leq j \leq n, i \neq j\}} p(A_iA_j|X)={n \choose 2}P(A_1 A_2│X)[/itex]
So, you mean that it is OK? Am I right?
thanks
thanks
It depends on what you mean when you say that the [itex]A_i[/itex] are events "of the same type".
Must go to an appoinment now. Back later.
Your idea is basically to take the formula
[tex]P( \cup_{i=1}^n A_i) = \sum_{i=1}^n P(A_i) - ...[/tex]
and solve for the last term on the right hand side, which is either plus or minus [itex]P(\cap_{i=1}^n A_i)[/itex].
The formula also applies when you restrict each of the [itex]A_i[/itex] by saying "given X", so that's OK.
What you aren't making clear (I think) is that you are assuming a large set of equalities such as:
[tex]P(A_1 A_2 | X) = P(A_3 A_4)| X) = P(A_3 A_5| X)[/tex] etc.
[tex]P(A_1 A_2 A_3| X) = P(A_2 A_3 A_4| X) = P(A_3 A_4 A_5 | X)[/tex] etc.
[tex]P(A_1 A_2 A_3 A_4| X) = P(A_2 A_3 A_4 A_5| X)[/tex] etc.
You should state this explicitly. You haven't revealed the application you are working on. It may be that you are dealing with independent events. Just remember that the fact that [itex]A1[/itex] and [itex]A_2[/itex] are independent does not mean that [itex]A_1|X[/itex] and [itex]A_2|X[/itex] must be independent.
