Is this correct- momentum question
  • Thread starter Thread starter klm
    Momentum
The discussion revolves around a conservation of momentum problem involving two clay balls colliding. A 20 g ball traveling east at 2.0 m/s collides with a 30 g ball moving at 1.0 m/s, 30 degrees south of west. The calculations confirm that the total momentum before and after the collision is conserved, leading to a resultant speed of approximately 0.411 m/s for the combined mass of 50 g. Participants emphasize the importance of resolving momentum into x and y components to accurately calculate the final velocity vector.
  • Understanding of conservation of momentum in two dimensions
  • Knowledge of vector resolution and component analysis
  • Familiarity with basic physics concepts such as mass, velocity, and momentum
  • Ability to perform trigonometric calculations involving sine and cosine
  • Study vector addition and resolution techniques in physics
  • Learn about conservation laws in collisions, specifically elastic and inelastic collisions
  • Explore the concept of momentum in two-dimensional systems
  • Practice solving similar problems involving momentum conservation with varying angles
Students studying physics, educators teaching mechanics, and anyone interested in understanding momentum conservation in collision scenarios.
klm
A 20 g ball of clay traveling east at 2.0m/s collides with a 30 g ball of clay traveling 30 degree south of west at 1.0m/s.
What are the speed of the resulting 50 g blob of clay?
so this is what i i did:
mivi=mfvf
vx= (.02)(2) / (.05) = .8
vy= (.03)(-1)/ .05 = -.6
is that much correct so far? and then i can use vy= v sin theta to find v?
hard to understand what you have done with your notations.
but this is clearly a conservation of momentum question. so remember this is a 2D problem, so both total momentun in x and y direction must be the same before and after.
sorry for the messy calculations!
i am basically finding the Vx = ( mass of ball 1)( velocity of ball 1) / ( total mass )
so Vx = ( 0.02 kg) ( 2 m/s ) / ( 0.05 kg ) = 0.8
and Vy = (.03 kg) ( -1 m/s) / (.05 kg) = -.6
(is the bold part in this equation correct? )
but i am a little confused if i can use this equation to find V now, Vy= v sin(theta)
As far as i understand it. you have two momentum vectors to begin with and you need to find the resultant vector. so due to momentum conservation, you get
\vec p_1 + \vec p_2 = \vec p_f
where \vec p_i = m_i v_i
the speed that you are after is really |\vec v_f|
so i don't need the components then? or did i find the components of Vf..?
do you know how to handle vectors? do u know how to add them?
first resolve everything into component forms and get two equations: one for each x and y
okay for the first ball: Vx= 2 and Vy= 0
second ball: Vx= -1cos(30)
Vy= -1sin(30)
would the be correct?
Let me see if I can give more detail about what you have done.
You have one ball of 20 g (0.02 kg) moving east at 2 m/s. It's scalar momentum is 0.02(2)= 0.04 kgm/s so the vector momentum is 0.04\vec{i}. I can see no reason to divide by total mass.
You have one ball of 30 g (0.03 kg) moving south at 1 m/s. Its scalar momentum is 0.03(1)= 0.03 kgm/s so the vector momentum is -0.03\vec{j}.
The total momentum vector before collision is 0.04\vec{i}- 0.03\vec{j}.
The combined balls must have the same momentum vector, so letting \vec{v} be its velocity vector, (0.02+ 0.03)\vec{v}= 0.04\vec{i}- 0.03\vec{j}.
NOW you can get the velocity vector by dividing that equation by the total mass 0.05 kg: \vec{v}= 0.80\vec{i}- 0.06\vec{j}
The speed is the length of that vector.
okay i think i understand what you did...but i thought for some reason you should divide by the total mass, but i think we somehow got to same place either way. but one question, should that 0.06 be 0.6 ( just want to make sure, not trying to be picky :)! so the speed would just be .8^2 + .6^2 and then the square root of that number.
because i seem to be getting 1 and that is incorrect...
Vy= -1sin(30)
That looks good to me! (Assuming +x to be along east direction and +y along north.)
Go ahead...
ok so for ball 2 Vx= -.866 and Vy= .5 and then the magnitude of that is .999
and ball 1 the magnitude is just 2
so if i have to do m1v1+ m2v2 :
(.02)(2) + (.03)(1)
no... u have to conserve linear momentum in each direction separately! (remember, momentum is a vector quantity.. so treat it as a vector... in 1-D, since it can be only positive or negative direction, you used to get result even considering as scalar -- but with apprpriate positive and negative signs.)
Of course it would be 2 for 1st ball, and 1 for 2nd ball. From this only you got these components!
Maybe it's a typing mistake.. but vy = -.5. Check it.
oh so is it -1
so .04i - .03j
haha yeah sorry. it is -.5, i forgot the neg sign sorry!
Conservation of linear momentum
In x-direction: m1*v1,x + m2*v2,x = (m1 + m2)*vf,x
In y-direction: m1*v1,y + m2*v2,y = (m1 + m2)*vf,y
okay sorry this might be a dumb question, but why do we need to break up the conservation into components?
okay so i got .2804 for vfx and -.3 for vfy and then i just do square them both and take the square root and get .411 which should be the speed correct?
we are not breaking conservation.. we are breaking momentum -- a vector quantity .. in two components.. and then applying conservation on each of these components individually, because we know that.. at 90 degrees, things do not interfere. (Angle between x and y-axis 90 degree) .. now if you will ask why it is so.. very simple, a vector quantity can affect another, only if it has a component in the latter direction.. and Cos 90 = 0!
seems good
16K
