Is x^6-2x^3-1 Irreducible Over Q?
  • Context: Graduate
  • Thread starter Thread starter T-O7
The polynomial x^6-2x^3-1 is irreducible over Q, as confirmed through analysis involving reductions modulo 2 and 3. The polynomial reduces to x^6+x^3+2 in Z_2[x], which has been shown to be irreducible. The discussion highlights the ineffectiveness of Eisenstein's criterion in this case and emphasizes the importance of checking cubic factors over F3. Ultimately, the polynomial's irreducibility over Q is established after confirming that it does not factor into lower-degree polynomials.
  • Understanding of polynomial irreducibility
  • Familiarity with Eisenstein's criterion
  • Knowledge of modular arithmetic, specifically reductions modulo 2 and 3
  • Experience with irreducible polynomials over finite fields, particularly F3
  • Study the properties of Eisenstein's criterion in depth
  • Learn about polynomial factorization techniques in finite fields
  • Explore the classification of irreducible polynomials over F3
  • Investigate advanced methods for proving irreducibility of higher-degree polynomials
Mathematicians, algebra students, and anyone interested in polynomial theory and irreducibility, particularly those working with rational coefficients and finite fields.
T-O7
Hi,
I need to figure out whether or not the polynomial
x^6-2x^3-1
is irreducible (over Q).
I don't think Eisenstein works in this case, and performing modulo 2 on this i get x^6-1
which is reducible over F2.
Any ideas? Incidently, if i let y=x^3, then i get
y^2-2y -1
which is irreducible over Q...but I'm not sure if that means anything about the original polynomial.
Sure enough, Eisenstein doesn't work as there is no prime p such that p\mid -1. However if you reduce modulo 3, you get (i hope)
x^6-[2]x^3-[1] = x^6+[-2]x^3+[-1] = x^6+x^3+[2] and this polynomial in Z_2[x] seems to be irreducible (at a first try I couldn't factor it in 2 polynomials of smaller degree, but you can try yourself). So if that polynomial is irreducible in Z_2[x] then x^6-2x^3-1 is irreducible in Q[x].
Hmm..okay. I was hoping I wouldn't have to resort to brute force hehe
OK, so I have shown that the polynomial x^6+x^3+2 has no linear or quadratic factors over F3, but how did you show it can't factor into cubic terms? I don't really know the irreducible cubic polynomials over F3, and it seems like there might be quite a few of them?
It won't be horrid, there are only 18 candidates for monic irreducibles of degree 3 (constant term must be non-zero), 10 of them will have roots. Trial division by the remaining 8 will be tedious though. Actually you can cut this down quite a lot, if you check that none of the monic irreducibles with constant term 2 divide your polynomial, then you know none with constant term 1 do (do you see why?).
Sorry, I don't have anything quicker to offer.
Yes, great, thanks for the tip. After a little tedious work, it turns out that it is irreducible over F3, so my original polynomial was irreducible over Q. Yay, thanks a lot :biggrin:
  • · Replies 16 ·
  • · Replies 24 ·
