Is this number algebraic or transcendental?
  • Context: Graduate
  • Thread starter Thread starter Dickfore
The discussion revolves around the nature of the number β, represented as 0.1010010001..., specifically whether it is algebraic or transcendental. Participants explore various mathematical representations and properties of this number, including its relation to series, continued fractions, and connections to known transcendental numbers.
  • Some participants define β as a decimal number with an infinite non-repeating pattern and express it as a series: β = ∑(1/10^(k(k+1)/2)).
  • One participant suggests that β appears to be transcendental, as they cannot envision a polynomial with integer coefficients having β as a root.
  • Another participant agrees with the transcendental view and mentions that the unusual form of β might even allow for a proof of its transcendence.
  • A participant introduces Morse-Thue's number, suggesting that if this number is transcendental, then β must also be transcendental if it can be expressed in terms of it.
  • There are discussions about the continued fraction representation of β, with one participant providing the first 100 terms and noting a lack of regularity, suggesting it resembles white noise.
  • Another participant proposes that the continued fraction expansion indicates that β is irrational, referencing a theorem from a textbook on algebra.
  • Some participants express uncertainty about the connections between β and other known sequences or numbers, such as the Thue-Morse sequence, and question the validity of certain claims regarding their relationships.
Participants express differing views on whether β is algebraic or transcendental, with some leaning towards transcendental and others exploring the implications of its irrationality. The discussion remains unresolved regarding a definitive classification of β.
Participants note that the relationships and properties discussed may depend on specific definitions and assumptions, and there are unresolved mathematical steps regarding the proof of transcendence or algebraicity.
Dickfore
When we first encounter irrational numbers, we usually define them as decimal numbers with infinite number of decimals that do not repeat in a periodic fashion. The canonical example one sees is the number:
<br /> \beta = 0.1010010001\ldots<br />
i.e. there is one more zero between each consecutive pair of ones.
Another way of representing this number is by a series. Let us find the positions of the ones in this representation. Let us denote by n_{k} the decimal position of the k-th one. Obviously, n_{1} = 1.
The number of zeros between the second and first one is 1.
The number of zeros between the third and second one is 2.
The number of zeros between the (k + 1)-st and the k-th one is k.
However, the number of decimal places between a figure in the n-th and a figure in the m-th place is equal to n - m - 1 (not counting the end decimals themselves). So, we can write the recursion.
<br /> n_{k+1} - n_{k} - 1 = k, \ k \ge 1<br />
<br /> n_{k+1} - n_{k} = k + 1, \ k \ge 1<br />
<br /> n_{k} - n_{k - 1} = k, \ k \ge 2<br />
which, together with the initial condition has the solution:
<br /> n_{k} = \sum_{j=1}^{k} {j} = \frac{k(k + 1)}{2}.<br />
As a sanity check, we confirm that this formula gives 1, 3, 6, 10 as the decimal places where the first, second, third and fourth one occur, respectively. The value of a one in the n-th decimal place is:
<br /> \frac{1}{10^{n}}<br />
Combining these results, we see that we can write \beta as:
<br /> \beta = \sum_{k = 1}^{\infty} {\frac{1}{10^{\frac{k (k+1)}{2}}}} <br />
The question is: Is this number algebraic or transcendental?
Without further analysis, it looks transcendental to me. I can't imagine a polynomial with integer coefficients having that number as a root.
I agree with mathman:
\beta = \sum_{k = 1}^{\infty} 10^{-k(k+1)/2}
is almost surely transcendental. Actually, the form is unusual enough that ot may even be provable, though I can't think of a way at the moment.
Well, I found this link http://sprott.physics.wisc.edu/pickover/trans.html". In it, one of the numbers, called Morse-Thue's number x = 0.01101001\ldots, which has a simple relation to my \beta as:
<br /> 100 \, x = 1 + \beta<br />
So, if \beta were an alberaic number, then any rational function of it is still an algebraic number. Since it says x is transcendental (without proof), we can conclude that \beta cannot be algebraic, i.e. it must be transcendental.
On to reading more about Morse-Thue's number.
The number 0.11010010001... is obviously related to your number and to your newly-found Morse-Thue's number.
Let s1=0.1, s2=0.11, s3=0.1101, s4=0.1101001, ... Writing sn as a rational sn=pn/qn, then
\aligned<br /> p_1 &amp;= 1 \\<br /> q_1 &amp;= 10 \\<br /> p_{n+1} &amp;= 10^np_n+1 \\<br /> q_{n+1} &amp;= 10^nq_n<br /> \endaligned
Suggestion: Try expressing it as a continued fraction. (Not a hint; when I say "hint" it means I know the solution.)
I found the first 100 terms in the continued fraction of \beta (not the number you suggested):
Code:
{0,9,1,9,11,9,11,90,1,9,1,90,110,9,12,4,1,3,1,4,2,1,4,4,10,1,10,9,1,907,2,1,2,6,3,1,4,1,9,1,1,4,2,1,2,1,1,1,8,5,10,1,1,3,1,1,4,2,1,1,6,3,1,6,2,1,3,1,4,6,2,6,1,39,2,1,7,1,1,2,11,2,2,1,8,1,1,13,28,89,1,1,5,1,26,1,3,2,1,8,2}
If you make a scatter plot of these values, you can't see any regularity:
I tried to see if there are some hidden periodicities in the sequence by performing the discrete Fourier transform. Here is the power spectrum:
It looks pretty much like white noise to me.
Finally! Sometimes LaTeX can be a beotch -- and I've been using it for decades.Not quite canonical form, but
<br /> 1.1010010001\cdots =<br /> \cfrac{1}{1-\cfrac{1}{11-\cfrac{10}{101-\cfrac{100}{1001-\cfrac{1000}{10001-\dotsb}}}}}<br />
Yeah, it might be true. I didn't check it. Nevertheless, is this a proof of transcendence? Because the continued fraction of \sqrt[3]{2} has no periodicity or regularity as far as I know.
EDIT:
Mathematica gives the result of the series in terms of elliptic theta function:
<br /> \frac{\sqrt[8]{10}}{2} \vartheta_{2}(0; \frac{1}{\sqrt{10}}) - 1<br />
Be aware that http://en.wikipedia.org/wiki/Thue%E2%80%93Morse_sequence" is not \frac{(1+\beta)}{100} as it goes on .01101001100101101001011001101001... so even if you found a proof for it, that wouldn't apply to your number anyway.
Which is exactly what I quoted as Morse-Thue's number. Nevertheless, even if it is connected through some transformation involving algebraic operations only, the proof still holds. BTW, Wikipedia gives an article for a sequence, not a number.
Assuming D H's continued fraction expansion in post #7, I think I can prove that \beta is irrational. Not what the OP was looking for, but it's a partial result. I use the following result, taken from p. 512 of Vol. II of Chrystal's Textbook of Algebra, AMC Chelsea edition, 1999:
17. If a_2, a_3, ..., a_n, b_2, b_3, ..., b_n be all positive integers, then
II. The infinite continued fraction
<br /> <br /> \cfrac{b_2}{a_2-\cfrac{b_3}{a_3-\cfrac{b_4}{a_4-\cfrac{b_5}{a_5-\cfrac{b_6}{a_6-\dotsb}}}}}<br /> <br />
converges to an incommensurable limit provided that after some finite value of n the condition a_n \geq b_n + 1 be always satisfied, where the sign > need not always occur but must occur infinitely often.
(Chrystal uses the word incommensurable to mean what we now call irrational.)
The continued fraction in post #7 satisfies these conditions. Thus \beta is irrational.
Petek
Isn't that already obvious because it doesn't recur?
Yes, you're right.
The Thue number is not clearly related to your number. The decimals with 1s in positions that are n(n+1)/2 or n^2, etc., are related to the Jacobi identity and, in particular,
Product [0 to infinity] {(1+x^n)(1-x^(2n+2))} = 2Sum [x^(n(n+1)/2)]
{I am having a little trouble seeing the product at n=0 and the 2 coefficient in the sum! Possibly, 1+x^n is not done at n=0 and there is no 2 on the right}
For x=.1, this gives (1+1)*(1-.1^2)*(1+.1)*(1-.1^4)*(1+.1^2)*(1-.1^6)*(1+.1^3)*(1-.1^8)*(1+.1^4)*(1-.1^10)*(1+.1^5)*(1-.1^12)*(1+.1^6)*(1-.1^14)... = 2( 1.1010010001...)
This does not prove transcendentalness, but gives new details.
  • · Replies 25 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 40 ·
