Can Electromagnets Achieve Levitation?
  • Context: High School
  • Thread starter Thread starter thebluser
The discussion revolves around the feasibility of using an electromagnet and a permanent magnet to achieve levitation. Participants explore the conditions under which levitation might occur, including the necessary strength of the magnets and the configuration of the setup.
  • One participant questions whether an electromagnet can levitate a magnet when powered, suggesting that sufficient current could counteract the weight of the device.
  • Another participant suggests conducting the experiment directly as a way to find out the answer.
  • A participant provides a basic outline of materials needed to create an electromagnet, indicating that it is relatively inexpensive and accessible.
  • One participant proposes that securing the levitating magnet is necessary for stability and asserts that levitation is possible if the magnets are strong enough.
  • Several participants reference external resources and projects related to magnetic levitation, indicating a variety of approaches and complexities in achieving this phenomenon.
There is no clear consensus on the feasibility of achieving levitation with the described setup, as participants express differing views on the practicality and requirements of the experiment.
Participants mention the need for specific materials and configurations, but there are unresolved details regarding the strength of the magnets and the stability of the levitation setup.
This discussion may be of interest to hobbyists, educators, and students exploring concepts of magnetism and electromagnetic applications.
thebluser
so let's say that i take and electromagnet and a magnet. i connect them to a position where if i turn on the power they will repel each other(the magnet is on top and is connected to the bottom electromagnet). my question: will it levitate when i switch the power on and increasing and deacreasing the flow to the electromagnet? imagine that there's enough electricity flowing to the electromagnet to repel the whole device weight. I am not sure youll understand this question but if you dont, its okay :p.
Why not just DO it and find out?
because i don't have the materials.
well its very cheap and easy to make an electro moagnet
... say 100ft of 20swg of enamelled copper wire, a piece of iron for the core say 4 inches long and 1 inch diameter approx ( not critical) and a power supply that can supply say ~ 12VDC at ~ 5Amps max
and many hobby shops will sell permanent magnets
Dave
You will need to secure the levitating magnet or electromagnet to a pole to keep it in a stable position, but yes it will levitate if the magnets are strong enough. You can do this experiment with 2 permanent magnets that are ring shaped. Stick them onto a rod or something that will hold them in position with like sides facing each other. Cheap and easy.
Using the Google search terms “science projects magnetic levitation” I found many sites describing such projects. Some are complicated, some are simple, but all of them illustrate the phenomenon of magnetic levitation. Here are just two to get you started:
http://www.paksc.org/pk/science-experiments/physics-experiments/item/792-magnetic-levitation-science-project.html
http://www.levitationfun.com/
See also youtube.
thank you all for your very good answers :)
  • · Replies 22 ·
  • · Replies 65 ·
13K
10K
  • · Replies 16 ·
