What is the Ke value for the given reaction at 1800ºC?
  • Thread starter Thread starter joejo
    Chem
The equilibrium constant (Kc) for the reaction CO2(g) + H2(g) = H2O(g) + CO(g) at 1800ºC is calculated to be 32.11. Initially, there are 2.0 moles of CO2 and 2.0 moles of H2 in a 1.0L container, with 0.3 moles of CO2 remaining at equilibrium. The correct equilibrium expression is Kc = ([H2O][CO]) / ([CO2][H2]), leading to the conclusion that Kc = (1.7 * 1.7) / (0.3 * 0.3) = 32.11.
  • Understanding of chemical equilibrium concepts
  • Knowledge of equilibrium constant calculations
  • Familiarity with stoichiometry in chemical reactions
  • Basic proficiency in LaTeX for formatting equations
  • Study the principles of chemical equilibrium and Le Chatelier's principle
  • Learn how to derive and use the equilibrium constant expression for various reactions
  • Explore the effects of temperature on equilibrium constants
  • Practice using LaTeX for chemical equations and expressions
Chemistry students, educators, and professionals involved in chemical engineering or reaction kinetics will benefit from this discussion on equilibrium constants and their calculations.
joejo
Hi guys can you please check if this is right...thanks in advance
Given the reaction CO2(g) + H2(g) = H2O(g) + CO(g). If initially there are 2.0 moles of CO2 (g) and 2.0 moles of H2(g) introduced into an empty 1.0L container, at 1800ºC, it is found that at equilibrium there are 0.3 moles of CO2 still present. Calculate the Ke value for this reaction at 1800ºC.
Initially 2 2 0 0
Equilibrium 2-1.7=.3 2-1.7=.3 1.7 1.7
Ke = 1.7 * 1.7/(.3 * .3) = 32.11
can anyone help me out please?
I would try but I don't know what Ke is. Sorry.
The Bob (2004 ©)
P.S. Sorry this post was a waste of time.
Alright here goes JoeJo:
This is the equilibrium expression for the reaction:
CO_2+H_2\leftrightarrows H_2O+CO
K_c=\frac{[H_2O][CO]}{[CO_2][H_2]}
This at the concentrations at equilibrium which as you indicated, only 1.7 moles of both reagents reacted. So even though it would be nice if you formatted it nicely like I did, your answer looks Ok.
lol thanks saltydog...i suck at latex...
shouldn't the answer be 0.03
JoeJo, your answer in #1 is corret, K_c=32.11. How do you end up with 0.03?
Kc=[H2O][CO] over [CO2]
= (0.3)^2 over (1.7)^2 = 0.03??
am i right or wrong?
Quote: "it is found that at equilibrium there are 0.3 moles of CO2 still present"
What is [CO_2]=[H_2]=? at equilibrium? By the way you're correct about
\frac{(0.3)^2}{(1.7)^2}
= 0.03
isn't that right...my first time with latex!
  • · Replies 22 ·
  • · Replies 44 ·
