Is this the right set mapping notation for a limit in two variables?
  • Context: High School
  • Thread starter Thread starter mcastillo356
The discussion centers around the appropriate set mapping notation for expressing a limit in two variables, specifically concerning the limit of the function \( f(x,y) = y\sin\left(\frac{x}{y}\right) \) as \( (x,y) \) approaches \( \left(\frac{\pi}{3}, 2\right) \). Participants explore the clarity and correctness of the notation used and the implications of defining limits in this context.
  • One participant presents a limit expression and a proposed set mapping notation, questioning its clarity and unambiguity.
  • Another participant asserts that in this specific case, the limit is unambiguous due to the behavior of paths in the local neighborhood.
  • Several participants discuss the implications of defining a constant function in the context of the limit notation, with some suggesting that it implies a function composition.
  • Multiple participants are working on an \( \epsilon/\delta \) proof of the limit, indicating a focus on rigorous mathematical justification.
  • One participant suggests that the use of topological definitions may be more appropriate for discussing continuity and limits in this context.
  • Another participant questions the necessity and effectiveness of an \( \epsilon/\delta \) proof for this particular limit, suggesting that basic theorems might suffice.
  • Concerns are raised about the correctness of inequalities used in the proofs and the assumptions made regarding the function's behavior.
  • There is a discussion about the continuity of the function and its implications for the limit, with references to the behavior of sine and Cartesian coordinates.
Participants express differing views on the clarity and appropriateness of the set mapping notation, as well as the necessity of an \( \epsilon/\delta \) proof. There is no consensus on the best approach to define the limit or the most effective notation to use.
Some participants note the potential pitfalls in the inequalities used and the assumptions about the function's continuity and behavior near the limit point. The discussion reflects a range of mathematical reasoning and varying levels of rigor in the proposed proofs.
This discussion may be of interest to students and professionals in mathematics and related fields who are exploring limits in multivariable calculus, particularly in the context of rigorous proofs and notation.
mcastillo356
TL;DR
I want to know if my attempt is well-defined, unambiguous.
$$\displaystyle\lim_{(x,\,y)\rightarrow{(\pi/3,\,2)}}{y\sin\bigg(\cfrac{x}{y}\bigg)}=2\sin\bigg(\cfrac{\pi}{6}\bigg)=1$$
Set mapping notation I've attempted:
$$\mathbb{R}^2\,\,\,\longrightarrow{\quad{\mathbb{R}}}$$
$$f(x,y)\,\longrightarrow{1}$$
No preview.
In this case, it is unambiguous since all possible paths in a local neighborhood lead to the same point. This in general not automatically the case.
mcastillo356 said:
TL;DR Summary: I want to know if my attempt is well-defined, unambiguous.
lim(x,y)→(π/3,2)ysin⁡(xy)=2sin⁡(π6)=1
R2⟶R
f(x,y)⟶1
No preview.
For me, the notation f(x,y)⟶1 means that you have defined a new constant function z⟶1 where z=f(x,y). You have defined the function composition (x,y)⟶f(x,y)⟶1.
I'm working on an ##\epsilon/\delta## proof of the limit of ##f(x,\,y)=y\sin\bigg (\cfrac{x}{y}\bigg)##. It will take me a while just to arrange an attempt.
Yes.
No preview
Yes.
No preview
##\left(\mathbb{R}\setminus \{0\},\cdot\right)## is a topological group, so inversion and multiplication are continuous, as is the sine function. Hence, your function is a sequence of continuous functions. I would use the topological definitions with open sets and write it down in those terms before I translated it into the ##\varepsilon-\delta## world. Especially the product topology, which you need for the multiplication in between, can be tricky in the latter.
Yes.
No preview
I'm not sure what an epsilon-delta proof of that would achieve. You can use epsilon-delta to prove basic theorems, then use those theorems to confirm continuity for more complex functions.
$$\displaystyle\int_{(x,\,y)\rightarrow{(\pi/3,\,2)}}{y\sin\bigg(\cfrac{x}{y}\bigg)}=1$$
means that
$$\forall{\epsilon>0},\,\exists{\delta>0}$$
such that whenever
$$0<\sqrt{(x-\pi/3)^2+(y-2)}<\delta$$
then
$$\bigg | y\sin\bigg(\cfrac{x}{y}\bigg)-1\bigg |<\epsilon$$
Proof
Given ##\epsilon>0##, we must choose ##\delta{(\epsilon)}## to be something.
Suppose
Check
$$\bigg | y\sin\bigg(\cfrac{x}{y}\bigg)-1\bigg |<|y|\Big | y\sin\bigg(\cfrac{x}{y}\bigg)-1\Big |<|y|\Big | y\sin\bigg(\cfrac{x}{y}\bigg)\Big |<|y|\bigg |\cfrac{x}{y}\bigg |=|x|\leq{\sqrt{(x-\pi/3)^2+(y-2)^2}}$$
$$y\sin\bigg (\cfrac{x}{y}\bigg )=t\Rightarrow{\cfrac{x}{y}} =\arcsin{(t)}+2\pi\cdot{K},\quad{K\in{\mathbb{K}}}$$
set ##k=0##
Then ##\epsilon=\delta## is the choice
Did I by the way define a neighborhood?
No preview
Except that the integral is probably a limit, the idea is ok.
We need to show that the preimage of an open set is an open set.
Set ##f(x,y)=y\sin\left(\dfrac{x}{y}\right)## and ##U(p,r)=\{q\in \mathbb{R}^n\,|\,\|q-p\|<r\}.## An open set in the domain around ##1## contains an open ball ##U(1,\varepsilon)=\{p\in \mathbb{R}\,|\,\|p-1\|<\varepsilon\},## and we want to show that ##f^{-1}\left(U(1,\varepsilon)\right)=\{(x,y)\in \mathbb{R}^2\,|\,f(x,y)\in U(1,\varepsilon)\}## is open. We therefore show that it contains an open ball ##U((\pi/3,2),\delta).## This means that we have to show that ##f\left(U((\pi/3,2),\delta)\right)\subseteq U(1,\varepsilon).##
Now we choose a point ##(x,y)\in U((\pi/3,2),\delta)## which means that $$\|(x,y)-(\pi/3,2)\|=\sqrt{(x-\pi/3)^2+(y-2)^2} <\delta\quad(1)$$
is given, and we have to show that
\|f(x,y)-1\|=\left|y\sin\left(\dfrac{x}{y}\right)-1\right|<\varepsilon\quad (2).
So we have to show the last inequality by using the first. However, I do not follow your inequalities. Yes, we may assume that ##|y|>1,## but this has to be noted for our choice of ##\delta## or must be proven. And then, the first inequality is ##\le ## and not strict, since the sine term could be zero. Regardless of those tiny mistakes, I do not see where the ##-1## and the sine in the next steps go.
The problem is to show that ##x/y## is near ##\pi/6## only using the Euclidean distance. I would show that ##f## is continuous, partially differentiable, and continuity follows from that. I have tried to use the series expansion, but with no luck. One has to get rid of ##x/y## first.
In fact, the cartesian coordinates are continous, and sine function too; this means the value of the limit at any points ##(x,\,y)## will be the same as the function's value. In this case:
$$\displaystyle\lim_{(x,\,y)\rightarrow{(a,\,b)}}{f(x,\,y)g(x,\,y)}=LM$$
##L## and ##M## being the values of ##y## and ##\sin{\Big (\cfrac{x}{y}\Big )}##
My attempt to prove the limit in a ##\epsilon/\delta## fashion is not wise at all.
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 18 ·
