Accuracy of the Formula xf=xi +vixΔt for Constant Velocity
  • Thread starter Thread starter anthony123456
The formula xf = xi + vixΔt is accurate for calculating final position when the x-velocity (vix) is constant, as established in the forum discussion. The experiment confirms that the distance traveled remains consistent over time, assuming negligible air resistance. The relationship between speed and position is directly proportional in the absence of acceleration, which is a key point for understanding the formula's validity. Participants emphasized the importance of recognizing conditions under which the formula holds true, particularly in experimental settings.
  • Understanding of kinematic equations, specifically xf = xi + vixΔt
  • Basic knowledge of constant velocity concepts
  • Familiarity with the effects of air resistance on motion
  • Introduction to calculus, particularly the relationship between speed and position
  • Study the implications of constant velocity in kinematics
  • Learn about the effects of air resistance on motion and how to account for it
  • Explore calculus concepts related to motion, such as derivatives of position
  • Investigate real-world applications of kinematic equations in physics experiments
Students in physics, educators teaching kinematics, and anyone involved in experimental physics who seeks to understand the relationship between mathematical formulas and experimental results.
anthony123456
Is the following formula accurate?: xf=xi +vixΔt
This question is for the hypothesis in our lab report. If we solve for the xf experimentally (in the lab), will the answer we get be the same if I do it mathematically. If so, why?
xf=xi +vixΔt
to solve for Δt, use: yf = yi + viyΔt + 1/2a Δt^2
vix is solved in the first part of the experiment...
The following formula is accurate as the x velocity is constant, thus whatever distance traveled, the distance traveled will be the same per second. What else can I say about it?
Yep. Maybe you are supposed to think of some reasons why the x velocity is not exactly constant in the experiment.
Thank you for responding. I need to say why the answers for xf will be the same (mathematically and experimentally). The vix is always constant, according to our teacher (air resistance is negligible).
Then maybe you are supposed to talk about why the equation is true given that the velocity is constant. Do you know much about calculus?
maybe, and I will be learning calculus next year. Why do you ask?
How can I explain that the equation is true?
Well, you are given that the speed is constant, and how (in calculus) are speed and position related?
I am not too sure... How are they related? Is it because there is no acceleration in the x-direction so speed and position are related proportionally, so to speak? This is a guess.
pretty much, but if you haven't done calculus, then I don't think you'd be expected to give this kind of answer. Maybe you are supposed to say why there is no acceleration in the x-direction, like why the air resistance doesn't affect the outcome in this case.
Ok thank you, I will do my best. Thank's for the assistance!
no problem!
  • · Replies 34 ·
  • · Replies 41 ·
