Isentropic two-stage compression work minimization
  • Thread starter Thread starter Deathcrush
    Thermodynamics
5 replies · 5K views
Deathcrush
Hi I would like you guys to help me with this problem
Air is to be compressed steadily and isentropically from 1 atm to 25 atm by a two-stage compressor. To minimize the total compression work, the intermediate pressure between the two stages must be
(a) 3 atm (b) 5 atm (c) 8 atm (d) 10 atm (e) 13 atm
P=sqrt(P1*P2)
I found that this pressure can be calculated with the square root of the product of those two pressures, however, i want to know where that equation comes from
thanks!
cmon, help me, please, how do you obtain that equation?
P=sqrt(P1*P2)
If there is any savings of work by doing it in two stages, the heat from the first compression has to be removed. So compress it to 1/5 of original volume (adiabatic), remove the heat and then adiabatically compress it further to 1/5 of this compressed state.
You should be able to show that if you do it any other way (eg. compress 1/2 then 1/12.5, or vice versa) you will end up doing more work. Write out the mathematical expression for work for the first compression to V1 + work for the second compression to Vf. You have to use the adiabatic condition (T and V) for each compression with a reduction in temperature to initial temperature after the first compression. When is the work a minimum?
AM
yeah, well, what i am interested in , is in finding how can I get that equation listed above, I had thought in deriving the equation for the sum of work in each phase, and finding the minimum value, however i can't set the whole thing to get that equation. Can I consider the air as an ideal gas? or how else can I get an equation P to integrate
Use the adiabatic condition for the first stage from V0 to V1:
[tex]T_0V_0^{(\gamma-1)} = T_1V_1^{(\gamma-1)}[/tex]
Since it is adiabatic, the work done is equal to the change in internal energy: [itex]W = nC_v\Delta T[/itex]
Do the same for the second stage. Then show that the minimum value for total Work is when V2/V1 = V1/V0 (ie. [itex]V_1 = \sqrt{V_2V_0}[/itex]).
AM
I think I'm getting it, I would thank you if you could recommend me some reading about this
