Isocleles Triangles in a Parabola Help
The discussion focuses on calculating the area of isosceles triangles formed by points on the parabola defined by the equation y = 9 - x². The area is expressed as a function of the x-coordinate of point A, resulting in the formula A = 9x - x³. The conversation highlights specific cases where points A and B share x-coordinates, yielding areas of 10 square units and approximately 4.75 square units, respectively. Participants explore various methods to derive a general equation for the area of all possible isosceles triangles inscribed in the parabola.
  • Understanding of isosceles triangles and their properties
  • Familiarity with the equation of a parabola, specifically y = 9 - x²
  • Knowledge of basic geometry, including area calculation using A = 1/2 bh
  • Experience with coordinate geometry and distance formulas
  • Research the derivation of area formulas for triangles in coordinate geometry
  • Learn about the properties of determinants in calculating areas of polygons
  • Explore advanced applications of Heron's Formula in triangle area calculations
  • Investigate the implications of varying triangle orientations in relation to parabolas
Students studying geometry, mathematics educators, and anyone interested in the application of calculus and algebra in geometric contexts.
Enderless
Triangle OAB is an isosceles triangle with vertex O at the origin and vertices A and B on the parabola y = 9-x^2
Express the area of the triangle as a function of the x-coordinate of A.
A = 1/2 bh
Distance formula (maybe)
Heron's Formula (an alternative)
The area of a triangle is given by A = 1/2 bh. If point A is (x, 9 - x^2), then b=2x and h = 9-p^2
The final equation will be A = 9x - x^3 (as a function of the x coordinate of A)
The equation above works only for a limited number of triangles embedded in the parabola. For instance, if A and B has the same x coordinates, then the equation will work. But i considered two different triangles that can make an isosceles triangle:
O = (0,0)
A = (2,5)
B = (2,5)
Area is 10 unites^2
and
O = (0,0)
A = (2,5)
B = (-2.2777902,3.8111609)
And the area will be around 4.75 units^2
Both of those are isosceles triangles, that can fit into the parabola of 9-x^2. How would I go about finding an equation that can find the area of all possible isosceles triangles in the parabola?
A = 1/2 bh
You mean 9- x2, of course.
O = (0,0)
A = (2,5)
B = (2,5)
Area is 10 unites^2
and
O = (0,0)
A = (2,5)
Yes, if OA and OB are the two congruent sides then the problem is easy as you say. Suppose, instead, that OA and AB are the conguent sides. Let (x0,y0) be the point A (and we may, without loss of generality, assume that x0 is negative. B= (x,y) must satisfy y= 9- x2 and (x-x_0)^2+ (y-y_0)^2= x^2+ y^2 If you multiply out the left side, you will see that the x2 and y2 terms cancel leaving -2x_0x+ x_0^2- 2y_0y+ y_0^2= 0 or (2x_0)x+ (2y_0)y= x_0^2+ y_0^2. It should not be too difficult to solve those two equations for x and y and then calculate the area of the triangle in terms of x0 and y0.
The case where OB and AB are the congruent sides is just the reflection of the previous case in the y-axis and gives the same area formula.
Another way is, that since the triangle is isosceles, the distance of the two points will be the same from y axis. If the coordinates of A are (x,y), the coordinates of B will be (-x,y). So, one coordinate will be (0,9) [vertex], (x,y) [A], and (-x,y) .
Now, we know that y=9-x^2 and the area of a triangle can be given by the determinant, D=\frac{1}{2}(0 9 1, x 9-x^2 1, -x 9-x^2, 1). (Sorry I don't know the tex for a determinant, hopefully someone who does could format it. Thank you.)
Solving this should be easy, specially if you use the properties of a det.
But the real question was about the case where the "base" of the triangle, the non-congruent line- was NOT parallel to the x-axis.
Sorry. My mistake. My case only works for the base parallel to the x axis.
For the other case, if you assume the coordinates of B to be (x_2,y_2) and of A to be (x_1,y_1) and since the vertex is at the origin, assuming OB to be the base, OA comes out to be \sqrt{x_1^2+y_1^2}.
The equation of the line OA comes out to be y=(\frac{y_1}{x_1})x. The distance of the point B from OA is \frac{y_2-\frac{y_1}{x_1}x_2}{\sqrt{1+\frac{y_1^2}{x_1^2}}}.
After solving for \frac{1}{2}\frac{y_2-\frac{y_1}{x_1}x_2}{\sqrt{1+\frac{y_1^2}{x_1^2}}}\sqrt{x_1^2+y_1^2}
The area is given by \frac{1}{2}(x_1y2-y_1x_2). If you could find a relation between x_1, y_1 and x_2,y_2 you would be home free... how would you do that though?
  • · Replies 40 ·
9K
10K
  • · Replies 40 ·
