Isothermal Expansion: Explained
  • Context: Undergrad
  • Thread starter Thread starter Fibo112
    Expansion Isothermal
This discussion clarifies the concept of isothermal expansion in ideal gases, specifically focusing on the relationship between internal energy, heat transfer, and work done. During isothermal expansion, the internal energy of an ideal monatomic gas remains constant, as it is solely dependent on temperature, not volume. The first law of thermodynamics indicates that the heat transferred to the gas equals the negative work done on it, leading to no change in internal energy. This principle is exemplified by the ideal gas law, PV=nRT, which demonstrates that pressure decreases as volume increases at constant temperature.
  • Understanding of the first law of thermodynamics
  • Familiarity with the ideal gas law (PV=nRT)
  • Knowledge of internal energy calculations for ideal gases
  • Concept of isothermal processes in thermodynamics
  • Study the implications of the first law of thermodynamics in various thermodynamic processes
  • Explore the characteristics of ideal versus real gases in thermodynamic contexts
  • Learn about the derivation and applications of the ideal gas law
  • Investigate the behavior of internal energy in non-ideal gases
Students of thermodynamics, physics educators, and professionals in engineering fields who require a deeper understanding of gas behavior during isothermal processes.
Fibo112
I am a little confused by the following; When an isothermal expansion takes place there is negative work done on the gas by the pressure, this I understand. Now by the first law the change in internal energy is equal to the heat transferred to the gas plus the work done it. So now in my script is says that for this isothermal expansion to take place there must be heat transferred to the gas(in the same amount of the negative work done). Now this means that the internal energy of the gas at the end is equal to the internal energy at the beginning right? This doesn't really make sense to me. Wouldn't a large volume of gas have more energy than a small volume of gas at the same temperature? I hope this question makes sense.
Science news on Phys.org
You have a larger volume of gas, but if you consider the ideal gas law, ## PV=nRT ##, the pressure must be reduced. Alternatively, since the gas has expanded, the density ## n/V ## is reduced, and also the energy density. ## \\ ## At the same temperature, the individual gas molecules have the same distribution of velocities, so if you sum the total of ## E=(1/2)mv^2 ##, you will get the same result for both volumes. For an ideal monatomic gas, the internal energy ## U=\frac{3}{2} nRT ## independent of the volume.
This is where we allow sometimes our intuition to fool us (larger volume hence more energy?!?), but it is a well know result that which Charles says that the internal energy depends only on temperature and not on volume (that is for the case of an ideal monoatomic gas, our intuition might not be completely wrong if the gas is not ideal it might depend on volume or other things as well).
  • · Replies 28 ·
  • · Replies 22 ·
