Jacobian and the dimension of a variety
  • Context: Graduate
  • Thread starter Thread starter GargleBlast42
    Dimension Jacobian
The discussion centers on the computation of the Jacobian for a system of polynomial equations in R^n and its implications for determining the dimension of the solution set at specific points. The Jacobian's kernel dimension is typically used to ascertain the number of independent directions at a point; however, this method fails when the Jacobian's rank is not locally constant. The example provided illustrates that while the kernel dimension can indicate independent directions generically, it may not accurately reflect the situation at singular points, such as x=y=z=0, where the dimension of the kernel can misleadingly suggest more independent directions than exist. The conversation highlights the need for alternative approaches to understand the number of irreducible components intersecting at a point.
  • Understanding of polynomial equations in R^n
  • Knowledge of Jacobian matrices and their properties
  • Familiarity with concepts of kernel and rank in linear algebra
  • Basic grasp of algebraic geometry and tangent spaces
  • Study the implications of singular points in algebraic geometry
  • Learn about the concept of tangent cones and their relation to Jacobians
  • Research the theory of irreducible components in algebraic varieties
  • Explore advanced topics in differential geometry related to Jacobians
Mathematicians, algebraic geometers, and students studying polynomial systems and their geometric properties will benefit from this discussion.
GargleBlast42
I have the following problem:
I'm studying a system of polynomial equations in R^n and I'm looking at the surface which is the solution set of this system. I'm mainly interested in the dimension of this surface at a given point.
Now, naively, one would try to compute the Jacobian (of the m polynomials defining the surface) and then the dimension of the surface in that point would be the dimension of the kernel of the Jacobian. The problem is, of course, that this works only under the condition that the rank of the Jacobian is locally constant. But what about the points where this isn't the case? Could one at least say something about the "number of independent directions in which one can go".
A simple example: Let's take R^3 (with cordinates x,y,z), for simplicity, and the equations:
xy = 0
xz = 0
Now the Jacobian is [[y,x,0],[z,0,x]]. So the kernel is generically 1 dimensional (in particular at the points y=0,z=0) and at the points with x=0 it is 2 dimensional, except the point x=y=z=0 where it is 3 dimensional.
This is in accordance with the geometric picture one has, in particular at the point x=y=z=0 we have three "independent directions" (tangent vectors) in which we can go, although the dimension is clearly not 3 at that point, since not all directions are allowed. Does this somehow hold in general - i.e. does the dimension of the kernel of the jacobian always give me the number of independent directions at that point.
I'm aware that the notion of a tangent space can break down in these cases and, unfortunately, I don't know what the appropriate terminology in these cases is, but I hope you understand intuitively what I mean.
Thank you for any ideas!
OK, I will partially answer my own question:
The Jacobian is not a reliable indicator of the "number of directions" on an algebraic set.
Simple example: the hypersurface in R^3 given by x^2+2xy+y^2, where the Jacobian is vanishing along the surface and so doesn't give the expected dimension.
I guess I'm trying to find the number of irreducible components intersecting at a given point and compute their dimension. But how can one see this from the defining equations?
  • · Replies 30 ·
  • · Replies 35 ·
