Period matrix of the Jacobian variety of a curve
The discussion focuses on computing the period matrix of the Jacobian variety of a smooth algebraic manifold X, specifically in relation to the Kawazumi-Zhang invariant of Riemann surfaces. Key resources mentioned include algorithms on algebraic varieties, particularly the book by Davenport, which discusses the Jacobian and provides an extensive list of references. The paper by Gross, along with its appendix by Rohrlich, is highlighted for its relevance to the computation of abelian integrals. Additionally, Mumford's "Lectures on Theta Functions, Volume II" is recommended for its explicit construction of the Jacobi variety of hyperelliptic curves.
  • Understanding of algebraic varieties and smooth algebraic manifolds
  • Familiarity with the concept of Jacobian varieties
  • Knowledge of abelian integrals and their computations
  • Basic understanding of Riemann surfaces and the Kawazumi-Zhang invariant
  • Study the algorithms for computing the period matrix in algebraic geometry
  • Read Gross's paper on abelian integrals and its appendix by Rohrlich
  • Explore Mumford's "Lectures on Theta Functions, Volume II" for constructions of Jacobi varieties
  • Investigate the references provided in Davenport's work on Jacobians
Researchers and mathematicians specializing in algebraic geometry, particularly those interested in the computational aspects of Jacobian varieties and Riemann surfaces.
GogoJS
Consider an algebraic variety, [itex]X[/itex] which is a smooth algebraic manifold specified as the zero set of a known polynomial.
I would appreciate resource recommendations preferably or an outline of approaches as to how one can compute the period matrix of [itex]X[/itex], or more precisely, of the Jacobian variety of the curve.
My motivation is I am studying the Kawazumi-Zhang invariant (related to the Faltings invariant) of Riemann surfaces, which can be expressed as a Fourier series in the period matrix, and thus if I can evaluate the period matrix [itex]\Omega[/itex] of the algebraic manifold, then I can compute its Kawazumi-Zhang invariant, numerically.
Not sure whether it helps, but I've found
https://www.amazon.com/dp/3540102906/?tag=pfamazon01-20
which deals with algorithms on algebraic varieties in the sense, that it is less about the mathematics but more about actual algorithms. In the section which is about the Jacobian (p. 106 ff.) Davenport refers to
https://www.amazon.com/dp/1614276129/?tag=pfamazon01-20
However, the latter might be more about boundaries than actual algorithms. A suspicion I have due to the year of its original publication (1959). E.g. the first one proves an upper bound on ##|Jac(C)|_K##. In any case Davenport provides a long list of references, which might be the starting point for further searches.
The question of explicit computation of "abelian integrals", as they are usually called, is one I know little about, but the following paper of Gross may be relevant. It contains an appendix by Rohrlich treating such "computations" in a special case, and also references a paper of Weil on this topic, [W3] in the bibliography of Gross's paper.
http://s3.amazonaws.com/academia.edu.documents/46450483/bf0139027320160613-7495-1pri9m8.pdf?AWSAccessKeyId=AKIAIWOWYYGZ2Y53UL3A&Expires=1485031611&Signature=ZmYs9hrDdN7BRFB8jNp71o73YOI%3D&response-content-disposition=inline%3B%20filename%3DOn_the_periods_of_abelian_integrals_and.pdf
Mumford's Lectures on Theta functions, volume II, gives an explicit construction, also following Weil, of the Jacobi variety of a hyperelliptic curve, (the projective closure of the locus) defined by an equation of form Y^2 = f(X), for a polynomial f. Maybe it could be useful.
https://www.amazon.com/dp/0817645691/?tag=pfamazon01-20
  • Poll Poll
  • · Replies 80 ·
11K
  • · Replies 25 ·
  • Poll Poll
  • Sticky
  • · Replies 20 ·
15K
