Estimating Kinetic Friction Coefficient of Jet-Powered Car
The discussion focuses on estimating the coefficient of kinetic friction for the jet-powered car "Spirit of America," which left skid marks of 18.70 km while traveling at an initial speed of 661.0 km/hr. The key equation used is fk = u * N, where u represents the coefficient of kinetic friction and N is the normal force. Participants emphasize using the work-energy theorem, where the kinetic energy (KE) dissipated during the skid can be equated to the work done by friction (W = Fd). The challenge arises from the absence of the car's mass, which complicates the calculations.
  • Understanding of kinetic energy and its formula (KE = 1/2 mv^2)
  • Familiarity with the work-energy theorem (W = Fd)
  • Knowledge of frictional force equations (F_fric = μN)
  • Basic principles of free body diagrams (FBD)
  • Research the relationship between mass, friction, and normal force in physics.
  • Learn how to derive expressions for normal force in different scenarios.
  • Study the application of the work-energy theorem in real-world problems.
  • Explore methods for estimating coefficients of friction experimentally.
Physics students, mechanical engineers, and automotive engineers interested in dynamics and friction analysis in high-speed vehicles.
envscigrl
Here is the problem:
When the jet-powered car "Spirit of America" went out of control during a test drive at Bonnevile Salt Flats, Utah, it left skid marks about 18.70km long. If the car was moving initially at a speed of 661.0km/hr, estimate the coefficient of kinetic friction between the tires and the road.
I know that the coefficient of kinetic friction can be found using the equation:
fk = u * N where u is the coefficient and N the normal force. But I cannot understand how I am supposed to find it with only the speed and distance. I tried finding the time (assuming V=0) then finding the acceleration and them finding the force with F=ma. But I was unsure if the f in the f=ma equation was equal to the f in the f=uN equation.
P.S.(I have converted the distance to meters (18700) and speed to m/s (186.618))
Thanks for your help and time!
Assume the engine shut down as soon as trouble occurred. Furthermore, you'll have to assume that drag is zero (unless this is given to you). Draw a FBD. What forces are acting on the car and in which directions? Once you know the forces and how they are working with relation to the direction of motion you can use the work/energy theorem to figure out how much work is done by the forces slowing the car down in order to dissipate the energy of a car going 187 m/s. Where you also given the mass of the car?
Anyway, good luck.
No the problem did not supply a mass that is what is tripping me up on the problem. If I had the mass it would be much much easier.
Energy is certainly a way to solve this problem. If the car had a Kinetic Energy of (1/2)mv^2 and this was completely dissipated over some distance, you can figure through conservation of energy that all of the KE went into work as described by the work equation W = Fd (force times distance).
Ah, but we don't have mass! Well, let's just keep going to see how things turn out. Start out by saying
KE = W
so...
\frac 1 2 m v^2 = Fd
Now, what is this F in the right hand side (i.e. what creates this force and what is our formula for it?) In your first post you said you already knew that the force slowing down the car was the force of friction. The formula for this is:
F_{fric} = \mu N
Now, \mu is what the question asks you to find, what about N? What is it based on? Find an expression for N, plug it into the frictional force equation, then plug that equation in for the force in our first relation and you might see some ways to simplify (i.e. cancel) a certain variable.
Thanks!
  • · Replies 16 ·
