Joint Distribution of Changing Mean
6 replies · 4K views
ghotra
Let X be a random variable with mean [tex]\mu[/tex] and standard deviation 1.
Let's add a twist.
Suppose [tex]\mu[/tex] is randomly distributed about 0 with standard deviation 1.
At each iteration, we select a new [tex]\mu[/tex] according to its distributuion. This mean is then used in the distribution for X. Then we pick an X according to its distribution.
My question: What is the resulting joint distribution? Given this joint distribution, I should be able to calculate the mean and standard deviation. Clearly, the mean X will be 0, but what will be the standard deviation of X? It seems that it should, at a minimum, be greater than 1.
Thanks!
let m=mean
E(X2|E(X)=m)=1+m2
E(m2)=1, since std dev(m)=1 and mean=0
Therefore E(X2)=2 or
std. dev.(X)=sqrt(2)
Could you elaborate a bit more? I can confirm that the std deviation is indeed sqrt(2), however, I don't understand where the following formula comes from:
E(X^2 | E(x) = m) = 1 + E(m^2)
From the definition,
[tex]\sigma_x^2 = E(x^2) - E(x)^2 = E(x^2) - m^2[/tex]
Presumably, I stick your formula into the formula I just wrote above...but I'm still confused where your formula comes from. Also, m (in my original post [tex]\mu[/tex]) is not the same...it is determined by a normal distribution.
I think the easiest way to do this is to simplify the description -- X is the sum of two normal distributions. (admittedly, it's good to be able to do it different ways, though)
Interesting, I had wondered if that was okay to do...as the variance of X would then be the sum of the variances of the two normal distributions...and this is, in fact, sqrt(2). Could you explain how these are equivalent pictures?
In general, I would like to consider a set of distributions
[tex]\mu_1 \sigma_1[/tex]
[tex]\mu_2 \sigma_2[/tex]
[tex]\mu_3 \sigma_3[/tex]
where the [tex]\mu_i[/tex] are distributed normally with mean [tex]\mu[/tex] and std deviation [tex]\Delta \mu[/tex]
where the [tex]\sigma_i[/tex] are distributed normally with mean [tex]\sigma[/tex] and std deviation [tex]\Delta \sigma[/tex]
For each distribution, we pick x once. What is the expected value of x and what is the standard deviation?
X is a normal distribution centered about u.
X - u is a normal distribution centered about 0.
X - u is, presumably independent from u. (You never actually specified in your problem that the only dependence of X on u is that u is the mean of the distribution on X, but I assume it was meant)
X = (X - u) + u
sig2(x)=E(x2)-m2
Presumably, I stick your formula into the formula I just wrote above...but I'm still confused where your formula comes from. Also, m (in my original post ) is not the same...it is determined by a normal distribution.
note: (You wrote: E(X^2 | E(x) = m) = 1 + E(m^2). If you look carefully at what I wrote I had m^2 on the right in that line and then took average over m on both sides to get E(X^2).)
In your expression for sig2(x), you implicitly defined it for a specific value of m. In the expression I wrote, I just made it explicit and rearranged terms, while using the fact that the variance of x is 1.
All I assumed about m is that it was random with first and second moments 0 and 1; normal distribution is unnecessary.
