Joule's paddle wheel experiment: temperature increase of water
19 replies · 6K views
lalahelp
If in Joule's paddle wheel experiment a block of mass 10 kg is allowed to fall through 22.5 meters and the mass of the water is 50 grams. What is the total increase in temperature of the water?
Can your value of J be used for determining how much mechanical energy can be produced from a specified amount of thermal energy?
Im not sure how to start the problems and do not know what to do could someone please help and explain them to me
What's the formula for potential energy (something with mass and height in it)?
And for thermal energy (something with mass and temperature in it)?
PE=mgh
Thermal energy= mct
what do I do from there?
Good! :smile:
lalahelp said:
PE=mgh
What would m be in this problem?
And g?
And h?
lalahelp said:
Thermal energy= mct
What would m be in this context?
Do you have a value for c?
How does t fit into your problem?
m=10 kg
g=9.8 m/s^2
h=22.5 m
___________
m=50 g
c=4185.8 kg c
t= I am not sure...
Right!
Now there is something called conservation of energy.
When your block falls, its potential energy has to go somewhere.
It is converted into heat.
What do you think the relation would be between the potential energy and the thermal energy?
As for "t".
What is it exactly that the problem asks you to calculate?
the potential energy equals the thermal energy?
the problem is asking for the total increase in temperature...
Exactly!
Yes. And "t" is the symbol for the change in temperature.
So...?
ohhh ok i got it Thank you!
could you explain the second question now lol your very helpful
J is mgh/mct
My book does not say anything about it, it just gives an equation so I am not sure...
Okay, so you can calculate J, can't you?
Can you put into words what J signifies?
Yes, J is usually the unit joule of energy.
That's why I asked, because the way J is used in your problem description suggests that J is used for something else...?
Where did your formula for J come from?
My physics book... its a conceputal problem. Yeh I was confused because it didnt say where that came from.
Conceptual problem or not, symbols always need to be defined before you can talk about concepts.
Is it defined as the formula you gave then?
So what's in the nominator of the formula? And what's in the denominator?
Do you recognize those?
