Reverse Integral and Evaluation: A Trick Question?
  • Context: Undergrad
  • Thread starter Thread starter NINHARDCOREFAN
    Test
The discussion centers on reversing and evaluating the integral \(\int_{0}^{\pi}\int_{x^2}^{\pi^2} x^3y \, dy \, dx\), with the correct reversed integral being \(\int_{0}^{\pi^2}\int_{0}^{\sqrt{y}} x^3 y \, dx \, dy\). A common mistake noted is the use of \(-\sqrt{y}\) as a lower bound, which is necessary when the region of integration extends into negative x-values. Participants emphasize the importance of visualizing the integration region to avoid errors and ensure accurate evaluations.
  • Understanding of double integrals in calculus
  • Familiarity with reversing the order of integration
  • Knowledge of evaluating integrals with variable limits
  • Ability to visualize integration regions in the Cartesian plane
  • Study techniques for reversing the order of integration in double integrals
  • Learn about the geometric interpretation of integration regions
  • Practice evaluating complex double integrals with variable limits
  • Explore common pitfalls in calculus related to integration bounds
Students and educators in calculus, particularly those focusing on integral calculus, as well as anyone looking to improve their skills in evaluating double integrals and understanding integration bounds.
NINHARDCOREFAN
One question on it was reverse the following integral and then evaluate it:
\int_{0}^{\pi}\int_{x^2}^{\pi^2} x^3y dydx
So I got the following reversed integral:
\int_{0}^{\pi^2}\int_{-\sqrt{y}}^{\sqrt{y}} x^3y dxdy
When you first evaluate in respect to x you get 0, am I doing something wrong?
minor mistake really... the second integral should be
\int_0^{\pi^2}\int_0^{\sqrt{y}} x^3 y \partial x \partial y
I really doubt you would lose a lot of marks
unless I've made a mistake which is possible
Yeah, as always, drawing out your region really helps. This is an interesting part of calculus where you can actually visualize things... unlike many other math courses.
Damn it, I put -sqrt(y) because in the book, the same problem (with x^2 in the lower bound of the first integral) like it put -sqrt(y) in the lower bound for it's solution. I would get lot of points taken off... it's a 15 point problem, the professors are harsh, i would get taken off -10 or something like that
The book problem...
The book problem was:
\int_{-2}^{2}\int_{x^2}^{4} x^2y dydx
Their answer was:
\int_{0}^{4}\int_{-\sqrt{y}}^{\sqrt{y}} x^2y dydx
Why was there a -sqrt(y) in this problem?
The reason for that comes from the fact that part of your domain for the region extends into the dreaded negative x.
and might i ask, did you mean to interchange the differential elements in the second integrand?
And also, NIN rocks!
Yes, I meant to do that. Damn it! I should have changed there right then because the problem would have never come out to zero. Oh well. Thanks.
  • · Replies 29 ·
