Keppler's 1st Law: Examining a Proof
  • Thread starter Thread starter rg057
    First law Law
The discussion centers on understanding the proof of Kepler's First Law, specifically the application of Newton's laws of motion and universal gravitation. A participant questions the presence of an extra vector 'r' in the equation, which is clarified as representing the direction of the gravitational force. The negative sign in the equation is explained as indicating the attractive nature of gravitational force. Additional requests for clearer explanations or links to more straightforward proofs are made, highlighting the complexity of the topic. Overall, the conversation emphasizes the need for a deeper understanding of the physics involved in Kepler's First Law.
rg057
i am examining a proof of kepplers first law for my conics project and I am a bit rusty on the physics, it begins withe the following line
To begin with, we will start off by applying Newton's law of motion and Newton's law of universal gravitation together to find that
m a = (-G m M/r^2) r
i think there is an extra r in this equation? if no where does it come from??
here is the link if it helps
http://members.kr.inter.net/joo/physics/curriculum/kepler/proof.html
The r is in bold which indicates its a vector. So the force of gravity has a magnitude of (-G m M/r^2) along the unit vector r.
thanks, altho the more I am looking at this the more i don't understand it,
can anyone explain where the negative comes from?
or if anyone knows of a link to a clearer proof, that would be appreciated also
The negative is there because the force of gravity is attractive.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
