Kilograms & Slugs: Solving the Units Paradox
  • Context: Undergrad
  • Thread starter Thread starter tehfrr
The discussion revolves around the differences between units of measurement in the metric and English systems, specifically focusing on the concepts of weight and mass as expressed in kilograms, pounds, slugs, and Newtons. Participants explore the implications of these units in the context of Newton's second law of motion, and how scales interpret weight and mass differently across systems.
  • Some participants express confusion about why scales in different systems report weight in pounds or kilograms, questioning if the units should be Newtons and pounds or kilograms and slugs.
  • Others argue that the scales provide an idea of mass, regardless of the unit used, suggesting that the distinction may not be problematic.
  • There is a mention that slugs are considered an archaic unit, with lbm (pounds mass) being the official unit, though slugs are still used in certain contexts.
  • Some participants highlight the difference between weight and mass, noting that conversions between kilograms and pounds do not account for gravity, which leads to confusion.
  • A technical clarification is provided regarding the definitions of force in both metric and English units, emphasizing the role of gravitational acceleration in these calculations.
  • One participant points out that digital scales may inaccurately assume a constant gravitational field when converting weight to mass.
  • There are discussions about the implications of using relativistic mass in the context of Newton's laws, with some participants debating the validity of F=ma under various conditions.
Participants do not reach a consensus on the interpretation of weight versus mass, the appropriateness of different units, or the implications of using relativistic mass in calculations. Multiple competing views remain throughout the discussion.
There are unresolved assumptions regarding the definitions of weight and mass, the conditions under which different units apply, and the implications of gravitational variation on measurements. The discussion also touches on the historical context of unit usage without reaching definitive conclusions.
tehfrr
Ok here's an easy one for you.
we start with F=ma
SI --> Newtons=kilograms*gravity
English --> pounds=slugs*gravity
So now why if you weigh yourself on an english scale it is in pounds, but if you stand on a metric scale it is in kilograms? I've solved plenty of F=ma problems throughout my college courses, but this question is something that just dosent seem clear to me. It seems that the units are wrong, shouldn't they be reading Newtons & pounds or kilograms & slugs? I never even heard of a Newton or a slug until I started studying engineering.
Well I have never dealt with pounds/slugs before but I don't see what the problem is. When we step on a scale that is metric, we get an idea of our mass by the kilogram value. However, if someone was to tell us how many Newtons we weighed, it would still give me an idea of my mass.
So perhaps In England, that's exactly what their doing.
It is all in how the lines are drawn on the scale. Americans weigh themselfs in lbs, Euorpeans , Mass themselfs in kg. What is the problem?
BTW I think slugs is an archic unit, the offical unit is now lbm, pounds mass.
well if a pound=slug*gravity then why do Euorpeans ignore gravity, and even offer such conversions such as 1 kilogram = 2.2046 pounds, they are different things being measured, weight vs mass
tehfrr said:
we start with F=ma
okay, i guess that means non-relativistic speeds.
not quite. Nt = kg * (1 m/s2)
gravity on Earth is about 9.8 m/s2
again, not quite. lbs = slug*(1 ft/s2)
gravity on Earth is about 32.174 ft/s2
a pound force is the force applied to accelerate a pound mass at the rate of 32.174 ft/s2 which happens to also be the acceleration of gravity. so if a pound mass is resting on the Earth, it pushes down with a force of one pound force.
a slug would weigh 32.174 lbs. that means it's 32.174 pound masses.
Abit Pedantic, but F=ma is valid for all constant accelerations if m is taken to be relativistic mass rather than rest mass.
The whole thing with Lbm is that, for most engineering calculations, one doesn't have to worry about the variation in the gravitational field. This permits the direct interchange between a Lbm and an Lbf. In realtion to the SI units and definition of a Newton, the true definition in the elemental units, 1 Lbf = 1 sl*g
If you want to use Lbm in F=ma, then you need, to be dimensionally correct, to introduce g_c where
g_c = 32.2 \frac{Lb_m*ft}{Lb_f*s^2}
and F=ma needs to be adjusted by
F = \frac{m*a}{g_c}
You can see that when you assume that one is at the surface of the Earth, at the equator, blah blah blah, g and g_c cancel out directly and an 1 Lbf = 1 Lbm. Of course, if you ever take a class that deals with space regimes like a rocket propulsion class I took, if you want to work in english units, you can't lose g_c
Personally, I hate dealing with it but I work for a company that has been around for a long time and a lot of the work done in the past directly interchanges the two units. Most people don't even take the time to distinguish between Lbf and Lbm.
Newton's second law does not say force is the product of mass and acceleration. Rather, it says force is proportional to this product: F=kma. The metric system was designed to make that constant of proportionality exactly one, or more precisely, 1 Ns2/kg/m:
F = 1\frac{{\text Ns}^2}{\text{kg}\cdot\text{m}} m\,a
We drop the 1 and the units conversion for convenience to write F=ma. We can do the same in English units so long as mass is expressed in slugs, acceleration in ft/sec2, and force in pounds force. The constant of proportionality cannot be ignored when mass is in pounds mass.
Slugs are still in use and are an official derived unit. Moments of inertia are almost always expressed in English units as slugs ft2, for example.
We use "weight" informally to mean "mass". When we say something "weighs" 6 pounds, we really mean it has a mass of 6 pounds mass. That 6 pound mass will still have a mass of 6 Lbm on the moon but will only weigh about 1 lbf.
A bit off-topic, the concept of relativistic mass was dropped in part because using F=ma is not valid. The relativistic mass changes depending on the direction of the force versus the direction of travel.
This is really the point. It doesn't necessarily have anything to do with the actual physics definition of the words, it is just what has become the popular convention. Technically speaking, you can't get mass from a spring-scale directly.
got it. seems like it's just a common language vs. scientifically correct terms issue then.
speaking of pendantic. it doesn't work that way, Gib. F=ma is just not correct, even if m is relativistic mass, for speeds close to c.
but F = dp/dt is correct, high speeds or slow.
Yes but doesn't dp/dt yield ma when acceleration is constant? I know having a constant acceleration has numerous troubles that have to be taken into account near c, but still.
What's really messed up is that there are digital scales that measure in kilograms--some of them measure weight and convert it to mass! How pompous they are to assume that we're weighing ourselves in a constant, 9.8 m/s^2 gravitational field!
no, but dp/dt becomes ma when the mass is constant. kicking into LaTeX:
F = \frac{dp}{dt} = \frac{d(mv)}{dt} = m \frac{dv}{dt} + v\frac{dm}{dt}
the first term of the sum you recognize and the second goes to zero in the context where mass is constant, which isn't the case when accelerating something close to c.
  • · Replies 23 ·
37K
61K
