Kinematic Equations: Find the time t when two objects meet
The discussion revolves around kinematic equations related to two objects, A and B, and their positions over time. The original poster attempts to find the time when both objects meet, but encounters difficulties in setting up the equations correctly due to the initial conditions and directions of motion.
  • Participants discuss the setup of the position equations for both objects, questioning the signs and directions of motion. There are attempts to clarify the conditions under which object B is moving towards object A and the implications of their initial positions.
Participants are actively engaging in clarifying the setup of the problem, with some offering guidance on visualizing the scenario through drawings. There is a focus on identifying errors in the original equations and understanding the implications of the objects' movements.
There is an emphasis on the initial conditions of the objects, particularly the fact that object B starts ahead of object A and the need for correct directional representation in the equations. The discussion highlights potential misunderstandings regarding the motion of the objects and their respective accelerations.
StephanieSamperio
Object A is at X=0m. Beginning at a time 0 s, A accelerates from rest at 2 m/s^2 in the positive x-direction. Object B is at X = 50 m at t = 0s and begins moving towards A from rest with an acceleration of magnitude 4m/s^2.
Part A) Where do A and B meet?
Part B) How fast is A moving when they meet?
Xf = xi + vi(t)+1/2(a)(t^2)
Vf = Vi+a(t)
Part A)
So, I set the two positions equations of A and B equal to each other since the position has to be the same.
A: 0 + 0 + 1/2(2)t^2 = 50 + 0 + 1/2(4)t^2 :B
I know I have to solve for time t, but there's no way to solve it with both sides having t^2 so I am not sure which variables I got wrong for the objects.
Hello Stephanie, :welcome: !
If you draw a picture, you will quickly see that B does not move towards A in your expression. Can you explain why not ?
Your equation reads
T^2 = 50 + 2T^2. That equation is easily solved for T. But your equation has a signage error.
Hi!
I think I could explain. B is already ahead by 50 m meaning it would have to be in constant acceleration while A catches up
PhanthomJay said:
Your equation reads
If there's two t^2 wouldn't they cancel out instead of being solved for?
StephanieSamperio said:
Hi!
No, then B still would move in the same direction as A and the given is that it does not. So there is something wrong with your expression. Draw a picture.
You would get that if accelerations of A and B would have the same value: A and B are 50 m apart and they stay 50 m apart. Again, because in your expression B does not move towards A
This is the picture I drew. Would object A need to have a velocity to be able to meet with Object B? I believe my mistake in my equations is with Object A
How come the arrow at B points in a different direction than the one at A :rolleyes: ?
(whilst they appear in the same way in your expression ...)
In the question, it says Object B is moving towards A from rest which is why I drew them in different directions
But the equation you wrote has them moving in the same direction.
So, @StephanieSamperio : how do you get B to move towards A (i.e. towards x = 0 , i.e. make xB decrease instead of increase) in your equations ?
  • · Replies 20 ·
