How long will it take for Sam to catch up to John?
  • Thread starter Thread starter harujina
    Kinematics
Sam is running at 3.8 m/s and is 75 meters behind John, who runs at 4.2 m/s, while Sam accelerates at 0.15 m/s². To find the time it takes for Sam to catch John, the equations for their displacements are set equal. The resulting equation is quadratic, requiring the standard form ax² + bx + c = 0 to solve for time. After some calculations, the correct time for Sam to catch up is determined to be approximately 34.4 seconds. The discussion emphasizes understanding the quadratic equation and solving it correctly to find the desired time.
harujina
Sam is running at 3.8 m/s and is 75m behind John who is running at a constant velocity of 4.2m/s. If Sam accelerates at 0.15m/s^2, how long will it take him to catch John?
d = (vf+vi/2)t
vf = vi + at
d = vit + 1/2at^2
vf^2 = vi^2 + 2ad
d = vft - 1/2at^2
I have asked this before, but have now come back with a little more understanding than before.
I've done the following so far:
Xs (displacement of Sam) = viΔt + 1/2aΔt^2
= (3.8m/s)Δt + (0.075m/s^2)Δt^2
Xj (displacement of John) = 75 + 4.2m/sΔt
[-> from: (xf-xi) = VavΔt
xf = xi + VavΔt ]
... Ok so now I do (3.8m/s)Δt + (0.075m/s^2)Δt^2 = 75 + 4.2m/sΔt
to find the time when they are in the same position/displacement, correct?
But I'm so confused as to what I would do after that?
EDIT; Also, I got 1005.33s for the time, and I don't think that's right?
What you got is a quadratic equation where delta t is unknown. Solve it.
ax^2 + bx + c = 0?
This may be a stupid question but how would I know which variable goes for which coefficient?
(I need to brush up on my math...)
harujina said:
ax^2 + bx + c = 0?
##x## is the unknown. In your case, the unknown is ##\Delta t##. You should be able to match the other symbols.
Okay I think I get it but then what was this for: (3.8m/s)Δt + (0.075m/s^2)Δt^2 = 75 + 4.2m/sΔt ?
I thought I was trying to find time with that?
I do not understand your questions. What does ##\Delta t## mean to you?
time, is it not?
It is time, and it is what you are after. What is not clear to you?
Well, my teacher said I had to find the position/displacement of both Sam and John, which I did:
(3.8m/s)Δt + (0.075m/s^2)Δt^2 for Sam and
75 + 4.2m/sΔt for John
and if I do: (3.8m/s)Δt + (0.075m/s^2)Δt^2 = 75 + 4.2m/sΔt
won't that give me time? So why would I have to do the quadratics equation?
Or am I doing something wrong here...
Because the equation you got is a quadratic equation. It will give you time - when you solve it.
OH, now I understand what my teacher was saying!
I got 32s, is that right?
You can check your answer yourself: you have the formula for displacement for Sam, and the formula for John. Do you get the same displacements at 32 s?
I got 34.4 seconds
(3.8m/s)(32s) + (0.075m/s^2)(32s)^2 = 198.4 m
75 + 4.2m/s(32s) = 209.4 m
so I am a bit off...
this is what i did:
(3.8m/s)Δt/t + (0.075m/s^2)Δt^2 = 75 + 4.2m/sΔt/t
3.8m/s - 3.8m/s + (0.075m/s^2)Δt^2 = 75 + 4.2m/s - 3.8m/s
(0.075m/s^2)Δt^2 / 0.075m/s^2 = 75 + 4.2m/s - 3.8m/s / 0.075m/s^2
Δt^2 = 75 + 4.2m/s - 3.8m/s / 0.075m/s^2
(square root)Δt = (square root)1005.33 s
Δt = 32 s
I do not know what you are doing, but you are not solving the equation correctly.
First you need to bring it to the standard form: ## a \Delta t^2 + b \Delta t + c = 0 ##.
Then use the (supposedly) well-known formula for its roots.
Likes 1 person
Okay I finally got it. Thank you so much and sorry for all the troubles!
No trouble at all. I hope this has been useful for you :)
20K
