Kinematics 2D: Find Particle's Accel. Vector
  • Thread starter Thread starter circuscircus
    2d Kinematics
To find the particle's acceleration vector, the initial and final positions along with the time interval are used. The particle's initial position is at \vec{r} = 2\hat{i} + 4\hat{j} m and its position at t=3s is \vec{r} = 8\hat{i} - 2\hat{j} m. The change in position over the time interval yields a velocity of \vec{v} = 5\hat{i} - 5\hat{j} m/s. To calculate the acceleration, the change in velocity must be divided by the time interval, leading to the correct acceleration vector. The confusion arises from the incorrect application of the formula, emphasizing the need to correctly account for both the change in position and velocity.
circuscircus
A particle moves in the xy plane with constant acceleration. The particle is located at \vec{r} = 2\hat{i} + 4\hat{j} m at t=0s. At t=3s it is at \vec{r} = 8\hat{i} - 2\hat{j} m and has a velocity \vec{r} = 5\hat{i} - 5\hat{j} m/s
What is the particle's acceleration vector a?
Here's what I did
\vec{a} = (\hat{r_{1}} - \hat{r_{2}}) / \Delta t - \vec{r} = 5\hat{i} - 5\hat{j}
The answer is just that without the \vec{r} = 5\hat{i} - 5\hat{j}
Could someone tell me why?
wait what is the answer?
  • · Replies 25 ·
  • · Replies 24 ·
