Kinematics moving particle problem
2 replies · 5K views · last reply
crybllrd
The position of a particle moving along the x-axis depends on the time according to the equation
x=ct[tex]^{2}[/tex]-bt[tex]^{3}[/tex]
where x is in meters and t in seconds. What are the units of (a) constant c and (b) constant b? Let their numerical values be 3.0 and 2.0 respectively.(c) At what time does the particle reach its maximum positive x position? From t=0 to t=2.0, (d) what distance does the particle move and (e) what is its displacement? Find its velocity at times (f) 1.0 (g) 2.0 (h) 3.0 and (i)4.0. Find its acceleration at times (j) 1.0 (k) 2.0 (l) 3.0 and (m)4.0.
I can't even get started on part a. I am not sure how to find the constants. The only thing I could think of would be using the final unit (m), so in that case one would have to be meters and the other seconds?
Am I on the right track?
You have x=ct2-bt3
'x' is in meters(m), so that the quantities ct2 and bt3 must also have units meters(m).
You know that 't' is in seconds (s), so 't2' has units s2, so what should the units of 'c' be such that (units of c)*(units of t2)= meters?
OK so for part A I have c=[tex]\frac{m}{s^{2}}[/tex] and B as b=[tex]\frac{m}{s^{3}}[/tex]. I believe the unit s should cancel out.
On part c I need to find a relative maximum. I can look at the graph and tell that t should equal 1. I was thinking to use the formula x=[tex]\frac{-b}{2a}[/tex] then plug x in for t in the given equation, but I don't think I can use that because it is not a quadratic.
