Kinematics of a point in rectilinear motion
The discussion focuses on the kinematics of a point Q in rectilinear motion with varying acceleration. Initially, the acceleration is 6 ft/s² to the right for the first 5 seconds, followed by an acceleration of 12t ft/s² to the left. The problem requires determining the initial velocity at t=0, given that the point is 13 feet to the right of the origin at t=7 seconds. The correct initial velocity is +2 ft/s, contrasting with the incorrect calculation of -15 ft/s presented by a participant.
  • Understanding of kinematic equations for motion
  • Knowledge of integration techniques in calculus
  • Familiarity with concepts of acceleration and velocity
  • Ability to analyze piecewise functions in motion problems
  • Review the derivation of kinematic equations in physics
  • Study the application of integration in solving motion problems
  • Learn about piecewise acceleration and its effects on velocity
  • Practice similar problems involving rectilinear motion with varying acceleration
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of rectilinear motion problems and solutions.
xzibition8612
A point Q in rectilinear motion passes through the origin at t=0, and from then until 5 seconds have passed, the acceleration of Q is 6 ft/s^2 to the right. Beginning at t = 5s, the acceleration of Q is 12t ft/s^2 to the left. If after 2 more seconds point Q is 13 feet to the right of the origin, what was the velocity of Q at t=0?
x''=a
x'=at+c1
x=(a/2)t^2+(c1)(t)+c2
At t=0:
x''=6
x'=6t+v0
x=3t^2+(v0)(t)
At t=5:
x''=-12t
x'=-6t^2+v1
x=-2t^3+(v1)(t)+x1
At t=7:
x''=-12t
x'=-6t^2+v1
13=-2t^3+(v1)(t)+x1
Now plug in t=5 s into the first set of equations and get:
75+(5)(v0)=x1
30+v0=v1
Plug these two equations into 13=-2t^3+(v1)(t)+x1
As for t in this equation, plug in 2 seconds because this new equation started at t=5 (and hence assume that to be the new starting point, thus 7-5=2).
I get v0 = -15 m/s
The book says the answer is +2. Obviously something went very wrong. Any help would be appreciated.
75+(5)(v0)=x1
30+v0=v1
How did you get the highlighted equation ?
plug t=5 into x'=6t+v0
Then knowing the fact that at t=5 the velocity is described by x'=-6t^2+v1, I set t=0 at this instant and thus 30+v0 = v1
you are using same constants on integration in different equations. the motion from t=5 to t=7
should have separate constants of integration from the motion t=7 onwards. that's why you are
mixing equations and got the wrong answer
But according to the problem, the motion at t=7s follows the same equation as the motion at t=5s (x''=-12), so shouldn't it be the same equations? Can you show me the correct equation? Because from the way I'm reading the problem my way to me is correct, when in fact it's not. I can't see it.
  • · Replies 20 ·
